Old 02-06-2010, 10:30   #1 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
We solved some bugs on server side at first SX4 Auth when phones had bad PM uploaded (e.g. PM308 from another phone, empty PM308, ...)
Now all SD repair should work well.
Here is general repair procedure.
It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....).
It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones.
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SD RPL repair
4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model
5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here:
http://rapidshare.com/files/34542441...e_by_MxKey.zip
http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip
http://www.4shared.com/file/21610198...thout_NPC.html
http://www.megaupload.com/?d=2MSDVYSY
Please report your results in this thread.
Akashub
The Following User Says Thank You to akashub For This Useful Post:
1000% All Sl1 & Sl2 Solved "SECURITY_TEST failed!" after SD repair jonysant MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 07-18-2010 15:58
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair MANOLE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 629 07-07-2010 07:15
[MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3" MANOLE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 164 05-05-2010 12:17
[MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3" MANOLE Service Products News & Updates 0 02-07-2010 23:17
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair MANOLE Service Products News & Updates 0 02-06-2010 10:10
Page generated in 0.12701 seconds with 9 queries
