Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 04-20-2012, 10:13   #1 (permalink)
Member: 773050
MXKEY supporter, need your help and answer (SOLVED)
Is it now MXKEY did not support for Nokia 2865 Contact Retailer Problem? Or something that I'm forget?
Note;
Please don't answer with; "Try to write with Original PM", cause it come with dead Flash IC, so I can't backup with it's original PM.
BR,
Old 04-20-2012, 11:11   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
bro. asking question & not want to see answer too, by the way post buscheck & selftest logs to solve.
Old 04-20-2012, 12:22   #3 (permalink)
gbluez's Avatar
Member: 73565
Find function DCT4 IMEI + Product Data inside RPL logger
Old 04-20-2012, 13:03   #4 (permalink)
Member: 773050
Than'k for reply, I'll post buscheck & selftest,
I've already done, but not fixed
Here is what I've already done:
RPL Calculation via Online Logger, with DCT4/DCT4PLUS IMEI+PRODUCT+BT+WLAN DATA RPL checked
RPL writing LOG
Reading ASK DATA ...
ASIC ID: 0x2051 [TikuEdge ver: 2.0]
SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
Supported Ids: 1051, 1052, 2051
FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 00000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
Performing Flash Authentication ...OK
UEM ID: 00A6D121:3B8ADA60
ASIC type: 6
UEM Imei: 03714298416
RPL saved to "C:\Phone Tools\mobileEx\3.5\data\backup\RPL\03714298416.RPL "
Programming FLASH Imei ...
FLASH programmed successfully.
Updating PROD_DATA ...OK.
ProductSpesificData validated OK.
Phone type: RM-193 (Nokia 2865)
SW version: V FL190V0200.nep 11-08-06 RM-193 (c)NMP
Esn plain: 03714298416
Esn OTP: 03714298416
Cellular system: CDMA
ASIC ID: 0x2051, type: 6
Ppm Id: G
Language Pack:
- not available.
Master code: 6647666052
Security code: 1234
SELFTEST after RPL done
Phone Type: RM-193
ID Test name Startup Result
46 UEM_CBUS_IF Y passed
15 SLEEP_X_LOOP Y passed
1 AUX_DA_LOOP Y passed
3 EAR_DATA_LOOP Y passed
17 TX_IDP_LOOP Y passed
18 TX_IQ_DP_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
8 MBUS_RX_TX_LOOP Y !no signal
39 WARRANTY N passed
51 PA_TEMP Y passed
10 PPM_VALIDITY N passed
7 KEYBOARD_STUCK N passed
21 LPRF_IF N passed
44 LPRF_AUDIO_LINES N passed
71 BT_WAKEUP N passed
41 FLASH_CHECKSUM N passed
107 PREPAID_CSTYPE N !failed !
22 CAMERA_IF N !no signal
54 EXT_RAM_DATA_BUS N passed
55 EXT_RAM_ADDR_BUS N passed
97 UEM_DBUS N passed
104 MFI_IQ_LOOPBACK N passed
96 APOLL_SLEEP_CLK N passed
98 BATMAN_PLL N passed
99 ROBIN_PLL_CELL N passed
100 ROBIN_PLL_PCS N passed
101 TX_PA_DETECT_CELL N passed
102 TX_PA_DETECT_PCS N !NOT EXECUTED(03)
24 CDMA_CORE N !NOT EXECUTED(03)
99 IRDA_LED_STRESS N !NOT EXECUTED(03)
96 HOOKINT N !NOT EXECUTED(03)
Final Check
Still Contact Retailer
Another thing
Write PM from working Phone, no change
Question
Whsre is faulty? Something missing or left?
BR,
Old 04-20-2012, 13:40   #5 (permalink)
gbluez's Avatar
Member: 73565
How to test:
Phone Tests->CS product type : Read
if OK log is: Reading product type and PP flags...OK
any other logs means is NOT OK.
- Flash the phone
- Write FULL PM from other phone. SKIP PM section 4,15
- REWRITE RPL + PRODUCT DATA
* do not write any PM after this *
test again same like above
The Following User Says Thank You to gbluez For This Useful Post:
Old 04-21-2012, 15:29   #6 (permalink)
Member: 773050
How to test:
- Flash the phone
I Follow your guide, but still not solved.
After Update to MXKEY version 3.5 rev 2.0 then repeated your guide...
ASIC type: 6
Ppm Id: G
Language Pack:
- not available.
Security code: 1234
Then test: Phone Tests->CS product type : Read
Phone is working right now,
Great thank's
BR;
Old 05-04-2012, 10:21   #7 (permalink)
Member: 1482882
download mxkey gmana bray
Old 05-06-2012, 03:24   #8 (permalink)
gbluez's Avatar
Member: 73565
Please go to alim home, near to you.
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.64735 seconds with 11 queries
