Old 02-04-2010, 07:58   #1 (permalink)
daveiant's Avatar
Member: 804247
Sonork: 1593659
Thanks Meter: 310
"MXKEY SX4 server is DOWN or UP?"
im confused about this error...
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 111.118.146.193
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 02-04-2010, 08:01   #2 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
this is not server problem , this phone dont have super dougle key,and also sl3
datz way showing this error,first repair sd then try to auth pm
mx-key server dont have any problem right now
Old 02-04-2010, 08:02   #3 (permalink)
mordant's Avatar
Member: 109758
Sonork: 100.1579682
Thanks Meter: 24
No SX4 Card found.
put phone info .....
Old 02-04-2010, 08:09   #4 (permalink)
daveiant's Avatar
Member: 804247
Sonork: 1593659
Thanks Meter: 310
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 15E00108E89E7C56B3DD967EBB9929A1FB388882
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 3593100XXXXXX
Original Product code: 0566832
Bluetooth ID: 002404EF7133
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 3593100XXXXXXX
Product Code: 0566806
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
TimeStamp: 2009-04-21T08:40:14Z
SW Version: 06.51
Variant Version: 011
ProductProfile: RM436_0566806_06.51_011.spr
Simlock: 0566806_simlock.bin
Imei net: 3593100XXXXXX
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-04-2010, 08:11   #5 (permalink)
marcdashale3126's Avatar
Member: 580978
Thanks Meter: 35
mx key team fix this error!!!!!
No SX4 Card found.
The Following User Says Thank You to marcdashale3126 For This Useful Post:
Old 02-04-2010, 08:14   #6 (permalink)
Member: 1081801
Using device: J.A.F, FW ver: 01.B1
Product: V 05.53 03-03-08 RM-174 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 7.406 s
RPL saved to "M:\mobileEx\3.3\data\backup\BB5_RM-174_356***************_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
Restarting phone ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
!warning: SD authorized but verify failed
Phone Type: RM-174 (Nokia 5200)
SW Version: V 05.53 03-03-08 RM-174 (c) Nokia.
Imei plain: 35***********************
Product Code: 0541045
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 3564***************
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
please see this
in this job sd is reapar but SECURITY_TEST failed!
Old 02-04-2010, 08:48   #7 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
see this link
http://forum.gsmhosting.com/vbb/showthread.php?t=917883
The Following User Says Thank You to WAJID PNR For This Useful Post:
Old 02-04-2010, 17:19   #8 (permalink)
Member: 1081801
Originally Posted by ktkwajid View Post
thx for you
but i read any post for this way
but i cant fix this 5200 and i think mx has bog and i think mx ky team working for this
tanks for mx ky team
Is sx4 server is down or what ???? TOZE MT-BOX 0 12-23-2009 14:33
jaf sx4 server is down for masterunlock1 Nokia Base Band 5 ( BB-5 ) 6 09-10-2009 23:06
SX4 server is working or not?? LordMen007 Universalbox 3 04-21-2009 07:37
Page generated in 0.29415 seconds with 9 queries
