10-10-2011, 09:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: south africa Age: 41
Member: 1269056 Status: Offline Thanks Meter: 1,114 | Mxkey synchronize file update ## v3.5 revision 1.4, Public-Release changes: - MAIN introduced HTI Firmware version 00.24 new in firmware: firmware accept SL3instant unlock activations bugfixed: BB5 security repair algorithm for RAPIDO new ASIC implemented WD2 and BTMCM flashing protocol implemented TIKU and MM(NAND) flashing protocol please Update HTI by using "Update HTI" button or "HTIUpdate.exe" improved: antivirus compatibility. improved: daily update check routine. improved: built-in downloader routine added: resume support bugfixed: handing big file size(more than 1G) added: support for upcomming windows 8(windows developer preview) support. added: Detailed 'LastError' message window when No Security Dongle Detected added: Detailed HTI identity(boot & fw version, serial) on connect. New Application released: MXKEY - Fire Agent(fire.exe), it brand new support tool and firmwares download support client Using shared configuration with corresponding module, simplify the needs to download/update firmware file. Working in sync mode with modules for better usage. using built-in downloader with resume support. Supported services: Nokia firmware, along with latest firmware notification info CDMA firmware, various vendor(Alcatel, Haier, Huawei, LG, Nokia, ZTE) more services tobe added at the future - Nokia Tool important informations(Asic ID, ROOT KEY HASH, UEM Imei) now highlited (beginner friendly). added: BB5 security repair function for RAPUv2 phones (beta testing) added: Verify Secure Data at 'Read SL3 Hash'/'Read Phone IDs', used to verify if secure data readed from the phone is valid to make sure the hash readed by software(both USB/FBUS) is 100% correct added: "Fire Support" menu in module`s options. added: support to load variant definitions created by fire.exe added: Spesified window dialog when card is busy/used by other module to fire.exe, sl3u.exe. added: support to convert log to other thirparty format to SL3BF module (sl3u.exe) added: new definition to 'phoneIdentity.ini.default' added: flash loader version 11.24.000.3 to setup added: RPL backup list load at scan (used for "Write Rpl' with 'Use RPL file' ticked) added: PM backup list load at scan improved: module initialization. improved: 'phone definitions loading' at first load. improved: 'HTI Auto BSI(SoftTMA)' set. improved: file/image version check routine. improved: Reboot after flash mode improved: WD2 flashing with HTI bugfixed: BTMCM flashing bug with HTI bugfixed: No Security Dongle Detected when HTI connected with phone(HTI power switched off on load) bugfixed: RAPIDO New Asic security repair function - CDMA Tool added: "Fire Support" menu in module`s options. MOHSIN FROM SOUTH AFRICA DONT FORGET TO THANX |
The Following 5 Users Say Thank You to trust4eve83 For This Useful Post: |
10-10-2011, 09:24 | #2 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: Bangladesh
Member: 671937 Status: Offline Sonork: 100.1613181 Thanks Meter: 94 | Quote:
BR | |
10-10-2011, 09:58 | #3 (permalink) |
Insane Poster Join Date: Apr 2006 Location: Pampanga City, Philippines
Member: 261347 Status: Offline Sonork: 1609207:kher2k Thanks Meter: 26 | Whats wrong with this kindly help??? after i update HTI it is OK but synchronize its failed..??? anyone can help this??? |
Bin files to 6150 | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 12-20-1999 14:08 |
Change Bin-file in Nokia..possible?? | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-20-1999 16:56 |
5110 ver 5.24 scr file | friendlypirate | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-06-1999 05:04 |
how can we use *.scr files to unlock | shadow77 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-27-1999 03:13 |
