Member: 118601
Thanks Meter: 200 | 6555 contact service fix but..... i have here Nokia 6555 RM-271 since 6 months with contact service when power on and press start phone "contact service". today conect it with mxkey then do scan later make unlock by code . it was just for test to see what is going to happen as i just receive my mxkey yesterday. surprise after unlock then scan again phone some test result was positif only superdongle key is invalid. power on phone no contact service again and IMEI is good. i don't test SIM CARD yet as battery is low but i'm sure is going to off after few minutes so WHAT NEXT TO FIX TOTALY THE PHONE? REPAIR SD BUT HOW TO FIX IT? i see the button SD repair.
here are log before and after unlock Quote:
Phone Type: RM-271 (Nokia 6555)
SW Version: V 03.46 30-10-08 RM-271 (c) Nokia
Imei plain: 35698401444747-3
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 22700210FD7E4E5092FE34207DF02248814E490C
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: A32E417B72C365977BB436843861AB6E35608542
Original Imei: 35698401444747
Original Product code: 0566126
Bluetooth ID: 001CD4160B8B
Phone not responding !
sing device: UFS_USB V2.8 (c) SarasSoft 2007.
Product: V 03.46 30-10-08 RM-271 (c) Nokia
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SIMLOCK using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 11.236 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-271_356984014447473_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Imei net: 356984014447473
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
