03-03-2010, 12:25 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 49
Member: 83984 Status: Offline Thanks Meter: 25 | mxkey team help,e63 contact retailer after unlock e63 succesfull but e63 shutdown in 25minutes.ı did this procedure http://forum.gsmhosting.com/vbb/showthread.php?t=920409 but e63 now contact retailer.please help me Phone Type: RM-437 (Nokia E63) SW Version: V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia Imei plain: 35150204085065-3 Product Code: 0568890 ApeCoreSw: 400.21.013 ApeVariant: 400.21.013, ApeTest: RM437ENO874571920.a01 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 351502040850653 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
03-03-2010, 13:01 | #8 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | than that is due to bad certifacates in the RPL upload RPL in this thread will check and post result http://forum.gsmhosting.com/vbb/show...44#post5512844 thanx |
03-03-2010, 13:01 | #9 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | about pm use search engine you will get pm edited by NOKIA BB5 PM Tested by Chevka, to solve the problem press npc the ime will damage, disconnect the phone and connect the phone restore imei, then repair sd, the phone will still restating, go to pm activate super dongle and write NOKIA BB5 PM Tested by Chevka, selct colect pm after that repair again sd the phone will not shut down and unlock will be ok if any problem do note estate off course i got experience with these proble of contact service, contact retair and phone shut down after three minute or when you play music |
03-10-2010, 21:48 | #10 (permalink) |
Junior Member Join Date: Dec 2008
Member: 935636 Status: Offline Sonork: isaac Thanks Meter: 0 | ow about this bro After after i did 1. i made fully back up, pm, certificate, and rpl, 2. go to pm read all neccessary data, reset pnc, will roose imei, do not worry, imei will turn to 1235, 3. erase flash then full flash , imei will still corrupted, 4. restore imei from back up , repair sd, this is the log how to handle Updating SIMLOCK...error 0x1???????? Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12217(18-02-2010) Product: V 07.95 03-02-10 RM-495 (c) Nokia Using cached productData[172000049C4F7F56F2E0740E3F5F6103840BC21D] ... Calculating SUPERDONGLE using security server ... Completed in 11.750 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-495_358006033353306_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...error 0x1 |
E63 contact retailer | arvinddald | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 03-19-2010 20:15 |
Ub team help E63 unlock error | mali_comm | Universalbox | 13 | 01-24-2010 11:46 |
help help help me out mxkey team help help help | mk_fono | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 10-12-2009 04:55 |
MT team help !!!!! E63 can't unlock | ptmobile | MT-BOX | 4 | 10-11-2009 10:09 |
Cyclone team help N96 Contact Retailer problem | quayson81 | Cyclonebox | 5 | 07-17-2009 10:30 |
