02-21-2010, 14:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | mxkey team help n73 Product Code: 0529607 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356862027269037 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Phone authenticated to SUPERDONGLE already. Phone authenticated to SUPERDONGLE already. Writing PM from Node ... Section: 1 - Key: 0 skipped - Key: 2 skipped - Key: 4 skipped - Key: 6 skipped - Key: 8 skipped - Key: 13 skipped - Key: 16 skipped - Key: 18 skipped - Key: 20 skipped - Key: 22 skipped - Key: 23 skipped - Key: 24 skipped - Key: 25 skipped - Key: 26 skipped - Key: 28 skipped - Key: 29 skipped - Key: 31 skipped - Key: 33 skipped - Key: 34 skipped - Key: 44 skipped - 308 skipped Section: 309 - Key: 0 skipped - Key: 1 skipped - Key: 2 skipped - Key: 4 skipped - Key: 5 skipped - Key: 7 skipped - Key: 8 skipped - Key: 17 skipped - Key: 22 skipped Completed in 1.923 s |
02-21-2010, 14:49 | #2 (permalink) |
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | after that all still same SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356862027269037 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-21-2010, 14:55 | #6 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Quote:
hi all here is guid of sl1 and sl2 soper dongel sl1 and old bb5 ( bb5>>sevice>>imei&securty>>imei rebuild>>npc back up>>reset npc>>repair sd>>write rpl>> now go to simlock>>repair splock now your fone is ok here is sl2 ((bb5>>sevice>>imei&securty>>imei rebold>>baup rpl all section>> repair sd ) now go to pm section only super sd auth betan clik injoy your fone now | |
02-21-2010, 14:57 | #8 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | download this pm files and select ur n73 pm and write with super sd auth http://www.mediafire.com/?ti1o01j5dzm |
02-21-2010, 15:14 | #12 (permalink) |
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | iting PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (6 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 6.880 s |
max key team help n73 ? | sajjadahmad | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-29-2010 16:59 |
Plz mxkey Team help! | LIEREN | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 12-28-2009 11:02 |
help help help me out mxkey team help help help | mk_fono | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 10-12-2009 04:55 |
mxkey team help me | shama | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 06-29-2009 20:59 |
