Old 02-10-2010, 10:13   #1 (permalink)
Member: 994459
Thanks Meter: 11
mxkey team how to solve this prb..- WD timer enabled, phone will reboot itself after
hello mxkey team plz help it solve this prob plz tell me any soloution this fault
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35193903150381-0
Product Code: 0550573
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351939031503810
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-10-2010, 10:15   #2 (permalink)
rudidar's Avatar
Member: 354893
Sonork: 100.1579833
Thanks Meter: 21
repair sd then write rpl pm..............
Old 02-10-2010, 10:24   #3 (permalink)
Member: 1194626
Thanks Meter: 34
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
DO YOU A NEW USER OF MXKEY...........THERE IS SO MUCH TREAD HAS TALK ABOUT YOUR PROBLEM........
FOR EXAMPLE...:
http://forum.gsmhosting.com/vbb/showthread.php?t=920409
The Following User Says Thank You to pritech For This Useful Post:
Old 02-10-2010, 10:28   #4 (permalink)
armanhosting's Avatar
Member: 410890
Thanks Meter: 88
use latest version 3.3rev1.4
then read all pm then backup rpl then click repair sd in imei and security then after successfull reparing of sd go to pm tab then edit the readed pm of your unit uncheck all adress only pm1 and pm309 are in check then click super sd atuh then write pm done....
Old 02-10-2010, 10:40   #5 (permalink)
xannix_7575's Avatar
Member: 847117
Thanks Meter: 71
just follow these STEPS::
1. open: service> imei & security> REPAIR SD(if DONE proced to atep 2)
2. open: PM> SUPER SD
3. tick LOAD FROM FILE (select PM 1 and 309 area only)
4. tick WRITE
when PM writing is DONE
to check if phone is OK, tick again BUS CHECK
for your PM file: http://www.megaupload.com/?d=6BAMQH0I
The Following 2 Users Say Thank You to xannix_7575 For This Useful Post:
Old 02-28-2010, 14:26   #6 (permalink)
Cheater -Don't Deal with him-
Member: 19627
Sonork: 1591544
Thanks Meter: 53
tested and working
sucefull repaired a 6120c and e63.
thanks
Old 02-28-2010, 16:00   #7 (permalink)
Member: 272796
Sonork: 1603232
Thanks Meter: 411
i have also repaird 6500c but it also doing this problem when i check it shows every thing is ok. but it turns of after 10 min some time 20 some time 30 like this
i have the RPL back file before i unlock and repair the phone... should i need to write it back and then start again or i shod do the SD repair and write pm and next
Old 02-28-2010, 21:35   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
Repair SUPERDONGLE procedure
next please spend your time for reading this thread
[MXKEY - TIPS] MXKEY in practice - What you should know about mobileEx -
br,
WD timer enabled, phone will reboot itself after 3 min. ## (ANSWERED) .::PATEL TELECOM::. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 43 10-02-2011 16:46
Nokia 3110c WD timer enabled, phone will reboot itself after 3 min jodhpur_raj MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 01-30-2010 22:59
WD timer enabled, phone will reboot itself after 3 min misterG MXKEY Nokia Flasher and Unlocker (by Alim Hape) 12 01-14-2010 03:20
WD timer enabled, phone will reboot itself after 3 min. ehsas_ghum MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 12-16-2009 12:11
WD timer enabled, phone will reboot itself after 3 min gul_hassan528 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 09-14-2009 22:18
Page generated in 0.16546 seconds with 9 queries
