MXkey TEAM please Look at This (ANSWERED) Start MobileEx http://images.devs-on.net/Image/z7ee...EO-Bereich.png when i tried to sign!!!!! http://images.devs-on.net/Image/ED2k...GQ-Bereich.png When i click Check Credit !!! http://images.devs-on.net/Image/lWK5...AE-Bereich.png I have tried all server,it`s the same problem. first sorry my bad english i have so manny Posts send over my problem ,bud nobody from mxkey team give a answered. i dont no why?? I am from germany my Reseller (Handy Smart)Tried to contact Manole Privat bevore over 3 weeks .he says he have no answered. My Mxkey Work perfect,bevore install MobileEx 1.7 I have treid to use with so manny MobileEx versions the problem still exist. If i start Suite give this message -- Could not verify apliccation signature,Please sign apliccation First. If i tried to sign ,give this messsage -- [UnauthorizedFault] Card [C0814741] have technical problem, please contact MXKEY team for more details (case id=0xCC06) reseller says is Blocked,is a Stupid server problem,is no big problem to solve - Bud nobody report from Mxkey team. i hope this time,read one of you,let work my MXkey and make me a lil bit happy .. THX. |
download the setup again n install it n try to sign the application if the problem persist wait till the server online again may be the error occur due to server down |
you are from Mxkey team ??? i think not then you can not help me and----- you did not understand me,read first and then post friend |
Install New Version 1.8 and check your computer time set if not match it could confuse progamm, you must delete all folder of Mobilex |
try to do it with new pc..... to ensure your pc no problem..... remember , manole is not yours, is not mine . he is ours. he is busy with update next version about mx. he send a post about turn off the host 1 and host2.. it maybe in touch with that... so ...sir ..... friend .... first you must be control your feeling . |
check your computer time and hour in pc your problem solved 1000000000000%%%%%%%%%%%%% goog luck |
date is Correct bro Problem not solved |
china? or other country. |
I am from Germany Mr lee |
sir ...... use other pc ... it will be ok ? or rebuild your xp system |
Bro`` Job is done bud problem still exist i need to call the ambulance we never have a chance :mad::o |
if still have problem disconnect ant-virus unstall all mex-key and delete all folder content, re- install again |
the solution is reformat the OS or windows xp install fresh! solved your problem! 100% tested ko na yan :) |
1st check you pc date.. 2nd install 1.8 3rd click sign application. |
THX Bud NOT Work !!! |
