Old 09-15-2010, 15:58   #1 (permalink)
Member: 1358778
Sonork: 100.872763
Thanks Meter: 33
Exclamation Mxkey team why this problem?
3110c when i complete flash then i select normal mode, then oky insert sim , when i disconnected my box the stil contact service!!
Pls advise me what i do ?
Bus Check:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1D40000108AF8B56A5E2ECED4BE2AF86C5821A0E
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Original Imei: 35 imei ok
Original Product code: 0550542
Bluetooth ID: 002668AAAB0D
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.30 07-05-09 RM-237 (c) Nokia.
Imei plain: 35 imei ok
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2008-11-12T09:10:26Z
SW Version: 07.21
Variant Version: 013
ProductProfile: RM237_0514950_07.21_013.spr
Simlock: 0514950_simlock.bin
Imei net: 35 imei ok
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Phone Info:
Version Info:
MCU SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
HW version: 2008
RFIC version: 17211721
DSP version: ICPR61_08w10
PPM version: V 07.30 07-05-09 RM-237 (c) Nokia. C
Retu version: 32
Tahvo version: 53
Content Pack version: Content: c_tr V 07.30 07-05-09 RM-237 (c) Nokia.
Product Info:
Production serial number: 7G1985250
Product code: 0514950
Module code: 0203291
Basic production code: 0542523
Serial Numbers:
IMEI plain:
35 imei ok
IMEI spare to net: 3A 65 60 01 13 57 89 02
IMEI SV to net: 33 65 60 01 13 57 89 22 F7
Other Info:
Model : Nokia 3110c (Classic Phone)
CS type : GSM900/GSM1800/GSM1900
BSI: 6.6 KOhm
Imei net:
35 imei ok
Counter: 0/3, 0/10
Self test:
Phone Type: RM-237
ID Test name Startup Result
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
15 SLEEP_X_LOOP Y !failed !
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N !not ready
20 BACKUP_BATT N passed
21 LPRF_IF N !NOT EXECUTED(03)
44 LPRF_AUDIO_LINES N !NOT EXECUTED(03)
2 CURRENT_CONS N !NOT EXECUTED(03)
42 RADIO Y PASSED(00)
69 BACKLIGHT Y PASSED(00)
33 SIM_LOCK N PASSED(00)
93 SECURITY N PASSED(00)
71 BT_WAKEUP N !NOT EXECUTED(03)
99 IRDA_LED_STRESS N !NOT EXECUTED(03)
96 HOOKINT N !NOT EXECUTED(03)
88 TAHVOINT Y PASSED(00)
56 SLEEPCLK_FREQ N !NOT EXECUTED(03)
101 BTEMP N !NOT EXECUTED(03)
107 BT_SLEEP_CLK N !NOT EXECUTED(03)
108 EXT_DEVICE N !NOT EXECUTED(03)
86 CDSP_RF_BB_IF N !NOT EXECUTED(03)
83 CDSP_RF_SUPPLY N !NOT EXECUTED(03)
85 CDSP_TX_IQ N !NOT EXECUTED(03)
74 CDSP_TXC_DATA N !NOT EXECUTED(03)
79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03)
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
Old 09-15-2010, 17:21   #2 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
its an hardware problem
change taro(bt ic)
The Following User Says Thank You to rakesh15 For This Useful Post:
Old 09-15-2010, 18:13   #3 (permalink)
Member: 1358778
Sonork: 100.872763
Thanks Meter: 33
change retu is also tied bro!!!!!!!!!!
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.15902 seconds with 9 queries
