Old 03-03-2010, 17:37   #1 (permalink)
Member: 775587
Thanks Meter: 29
MXKEY took 22 minuts to flash 2700c RM561
Version from phone: 07.80
Version from file: 07.81
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1880020A6DD98C5605C69FD034BF4480EAE3AC17
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 1.30.0 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM]  version: 1.31.0 revision: 0.0 size: 0x297E0
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35832403279557
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35832403279557_BACK.rpl"
Processing file: rm561__07.81.mcusw as MCU
 [BB5,BB5 ALGORITHM]  size: 19.41 MB
 Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Storing certificate ...OK
Total erase size: 21.00 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [00140000-0137FFFF]
CMT NOR area [01380000-0151FFFF]
erased in 1 min 51.016 s
Flash programming ...
CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100303220 (RAP Certificate 202 v.1) written.
Programming completed in 6 min 11.671 s
Processing file: rm561__07.81.ppm_ea as PPM
 [BB5,BB5 ALGORITHM]  size: 5.73 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF]
erased in 37.407 s
Programming completed in 1 min 48.547 s
Processing file: rm561__07.81.image_ea_blac as CNT
 [BB5,BB5 ALGORITHM] page size: 128 K size: 8.38 MB
NOR page size in the phone is 128 K.
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF]
CMT NOR area [02160000-03FBFFFF]
erased in 3 min 46.734 s
Converting UCP blocks to 128 K.
Programming completed in 2 min 38.672 s
Flashing completed in 21 min 19.688 s
Phone Type: RM-561 (Nokia 2700 classic)
SW Version: V 07.81 26-08-09 RM-561 (c) Nokia
Imei plain: 35832403279557-9
Product Code: 0579811
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358324032795579
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 21 min 44.422 s
ITS SLOW OR FAST, What u peple will want to say.
Last edited by gbluez; 03-03-2010 at 19:11. Reason: next time please use [code] on log
Old 03-03-2010, 17:43   #2 (permalink)
bad_signal's Avatar
Member: 107069
Thanks Meter: 31
it is very slow
but it is good
mx-key can flash that model
br
Old 03-03-2010, 17:45   #3 (permalink)
bad_signal's Avatar
Member: 107069
Thanks Meter: 31
same with 5130c
have alook
Version from phone: 07.95
Version from file: 07.95
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0EB000033AF08A5684C35B7A701FDB676945167E
ASIC MODE ID: 00
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Flash Imei: 35605303991056
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35605303991056_BACK.rpl"
Processing file: rm495__07.95.mcusw as MCU
 [BB5,BB5 ALGORITHM]  size: 18.20 MB
 Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
erased in 1 min 35.172 s
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 6 min 3.281 s
Processing file: rm495__07.95.ppm_er as PPM
 [BB5,BB5 ALGORITHM]  size: 6.37 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
erased in 33.766 s
Programming completed in 2 min 10.609 s
Processing file: rm495__07.95.image_er_red as CNT
 [BB5,BB5 ALGORITHM] page size: 128 K size: 12.01 MB
Formating FS: FILE2 ...
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
erased in 3 min 7.907 s
Programming completed in 3 min 59.750 s
Flashing completed in 21 min 49.672 s
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.95 03-02-10 RM-495 (c) Nokia
Imei plain: 356------------
Product Code: 0576616
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 356------------
Counter: 0/3, 0/10
Total time to process is 22 min 11.500 s
see ?
Last edited by gbluez; 03-03-2010 at 19:10. Reason: next time please use [code] on log
Old 03-03-2010, 17:49   #4 (permalink)
bad_signal's Avatar
Member: 107069
Thanks Meter: 31
i think that is phone problem
br
Old 03-03-2010, 17:50   #5 (permalink)
rockgsm's Avatar
Member: 420862
Thanks Meter: 51
2700c does take around 20min to flash in HWK & JAF too, so it is normal so no problem with MX-KEY .
regards
rockgsm
Old 03-03-2010, 18:30   #6 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
can u all try to flash 2700 and 5130 with USB and post the result here ..
that will be helpful ..
Old 03-03-2010, 19:12   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
yes, it is normal. do backup on fbus, and better use usb on flashing.
Old 03-04-2010, 05:30   #8 (permalink)
Member: 775587
Thanks Meter: 29
MXKEY can try to make it fast.
Old 03-04-2010, 06:11   #9 (permalink)
Member: 1011547
Thanks Meter: 342
yes it will take less time on usb
Old 03-04-2010, 06:18   #10 (permalink)
ericnite101's Avatar
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
100% Agree with you bro...... Better to use FBUS for backup and USB for flashing.... It might take less minutes for flashing.... I'll try and post results.. Thanks
ERIC
Old 03-04-2010, 06:37   #11 (permalink)
pankajkukar2's Avatar
Member: 609329
Sonork: 100.160.2296
Thanks Meter: 143
usb flashing is really fast
Old 03-04-2010, 06:58   #12 (permalink)
Member: 272970
Sonork: 100.1604883
Thanks Meter: 39
it is slow bro..even in usb flashing.there is no difference like before.
Old 04-21-2010, 13:23   #13 (permalink)
Member: 1263603
Thanks Meter: 2
hi can i get the flash files formy 2700c rm561 v.7?
Old 04-21-2010, 13:25   #14 (permalink)
Member: 1263603
Thanks Meter: 2
am using the ufs box but have an emulator so its used like jaf,how do i flashing using usb?
Old 04-21-2010, 13:30   #15 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
erased in 37.407 s
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Yes, same with me today I tried to flash 2700c RM-561 but error used UFS interface with flash loader error version.
I was trying used HWK flashing is okay.
Manole, please solve this...
regards,
setool took 2 credits to unlock T303 deep_sing SETool2 15 04-22-2010 15:51
Mxkey team plz update first 5130c2, 2700c unlocking abdurrahimsagar MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 03-29-2010 07:27
ineed turky file 2700c RM561 (rm561__07.80.ppm_ad2) h5ha Nokia Base Band 5 ( BB-5 ) 5 01-20-2010 18:47
L770 took 6 hours to unlock hasnain NSPRO 1 06-29-2009 08:55
Took Too Long To Flash Lg C2600 .:KHALIFA:. Infinity-Box 2 07-30-2007 21:14
Page generated in 0.28463 seconds with 9 queries
