Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Apr 2008 Location: home of Nonito Donaire
Member: 762556 Status: Offline Thanks: 71
| mxkey user , pls how can i fix this error pls mx key user how can i fix this trouble on 6151 RM-200 SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 352284012073932 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED TIA... |
| | #3 (permalink) | |
| Quote:
Product: V 04.10 21-12-06 RM-200 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving Unlocked PM, please WAIT ... OK Unlocked PM saved to "C:\mobileEx\3.3\data\backup\352284012073932_UNLOC KED_308.1.PM" Writing Unlocked PM ... OK Completed in 42.047 s Restarting phone ... Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! | |
| | #4 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2007
Member: 507861 Status: Offline Thanks: 187
| mei & security\simlock\SELECT repair SIM LOCK NOT INIT SIMLOCK .....THATS ALL YOUR PHONE WILL BE OK... |
| The Following User Says Thank You to ELOY1024 For This Useful Post: |
| | #5 (permalink) | |
| Quote:
| | #8 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Online Sonork: 100.1592732 Thanks: 61
| Quote:
for emergencey case1 repair SD 2 simlock RPL 3 PM with sx4 all will be OK | |
| The Following User Says Thank You to haji rahim For This Useful Post: |
| | #9 (permalink) | ||
| Quote:
repairing sd error ............ Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...error 0x2 making simlock rpl.................... Calculating SIMLOCK using security server ... Completed in 2.672 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-200_352284012073932_SIM.RPL" Updating SIMLOCK...error 0x2 Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! SX4 error ................... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 112.198.79.68 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request...... ![]() | ||
| | #10 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks: 210
| Quote:
| The Following User Says Thank You to shahinahmed007 For This Useful Post: |
| | #12 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2006
Member: 405696 Status: Offline Thanks: 21
| starting from mobileEx 3.3 Rev1.6, now repair SL and SD is done by single button "repair SD". So if you want to repair SL, the whole procedure is as simple as: 1. backup RPL(just in case). 2. erase EEPROM. 3. Repair SD 4. Full Factory 5. SUPER SD Auth + Write PM1,309 if these steps still not fix the phone, please do BB5 Cert Validation + repair procedure as described on previous post above. pls. be sure that you are always using the latest release nokia module (Option > Nokia Service Tool > Update) |
| The Following User Says Thank You to Ramzan khan For This Useful Post: |
| | #13 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2009 Location: FAISALABAD, PAKISTAN
Member: 1146078 Status: Offline Thanks: 3,305
| repair sl zone and write pm file with sx4 then unlock it |
| The Following User Says Thank You to shaazad For This Useful Post: |
| | #14 (permalink) | |
| Quote:
make up my thread.... problem still after erasing eeprom.... sd reoair................... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 03.91 25-09-06 RM-200 (c) Nokia Using cached productData[1F60020353D401542DFEBAE8450E30DBC3DBAACE] ... Calculating SUPERDONGLE using security server ... Completed in 7.750 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-200_352284012073932_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...error 0x2 full factory failed.... SUPER SD Auth.......... error Product: V 03.91 25-09-06 RM-200 (c) Nokia ERROR: Missing SD BLOCK or PM corrupted ! BB5 Certification reading error... Reading RAP NPC (0x168 bytes) Original Product Code: 0543972 Reading RAP VARIANT (0xC8 bytes) Product Code: 0520042 Product Code missmatch ! Reading RAP CCC (0x0 bytes) Reading RAP HWC (0x0 bytes) current status of phone... "after power on nokia only then off..." BB5 secure storage Validation.... SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed... Any Idea.................... ![]() | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how can i solve this error?' im new. | djkiddrick | Cruiser Suite | 5 | 04-01-2010 22:51 |
| how can i fixed this problem of P900 in the end | makkah mobile | Cruiser Suite | 1 | 02-19-2008 19:44 |
