04-07-2010, 12:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 38
Member: 319435 Status: Offline Thanks Meter: 260 | MXKEY v3.3 revision 1.7 - Public discussion threa MXKEY v3.3 revision 1.7, Public-Release Direct link for download MXKEY V3.3 revision 1.7: http://rapidshare.com/files/36502840..._20100318_.exe - Added, support for JAF BOX firmware 01.B4 - Fixed, Runtime Error when multiple instance loaded - Small ui changes, added module icon in menu. NK - Added, BB5 Warranty Unlock function !!! FIRST IN THE WORLD !!! Warranty Unlock will read unlock codes without direct write to the phone. Thus will make sure that the phone`s warranty is not void, a window will display the phone information, unlock codes and intruction to enter the codes as well. ~ a template file as html doc located to "\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\codtemplate.htm". ~ you might edit this template as you want as long as keep the variables "%model%","%imei%","%provider%","%codes%" and %codes7%. - Added, CMLA_KEY and SUPERDONGLE_KEY RPL backup - Added, New Loader/Protocol support for JAF BOX (RAPIDO,RAPU based phones) - Added, Multi-ReLock support As requested by some user, now possible to LOCK the phone to multi-providers. As the providers settings are maybe outdated, you might need to edit the providers list: ini file setting located to "\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\providers.ini". the format is [8DIGIT MCC+MNC]=[PROVIDER_NAME]|COUNTRY eg: 23430000=Virgin|United Kingdom - Added, Method1 (old) and Method2 (new) option for DCT4PLUS SIMLOCK Patch (will be used in future DCT4PLUS unlock updates) ~ Fast Flash routine will collect the list image files and process with one boot. NK - Previous changes(rev 1.6 Partial-Update) - Added BB5 RAP3GV4 USB Flashing(eg. Nokia X3-00,X6-00) - Added Dead Usb option for normal usb flashing (This will force software to use dead usb protocol without need to reconnect the Nokia USB ROM connection) - Many Minor bug fixes BB - Previous changes(rev 1.6 Partial-Update) - Added, manual checkbox to allow input IMEI+MEP manually(in case of usb connection problem). - Added, Engineering Screen Unlock code calc. RapidShare: 1-CLICK Web hosting - Easy Filehosting enjoy ........... by manish |
The Following User Says Thank You to manish_sk For This Useful Post: |
MXKEY v3.3 revision 1.7 - Public discussion thread | MANOLE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 491 | 08-19-2010 00:44 |
NEW UPDATE FIXMXKEY v3.3 revision 1.7 - Public discussion thread MXKEY v3.3 revision | guy_askali | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-22-2010 17:18 |
MXKEY v3.3 revision 1.7 Cant display nokia Tool | benny Haraba | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-22-2010 07:13 |
MXKEY v3.3 revision 1.7 can not flash use jaf | boysam | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 03-22-2010 02:57 |
