View Poll Results: Did you know that MXBOX is WORLD FIRST and the ONLY NOKIA BOX with TMA included ?
YES, i know MXBOX is WIRLD FIRST and ONLY one NOKIA box with TMA. 1,379 77.25%
No, I didn't know. 406 22.75%
Voters: 1785. You may not vote on this poll
Old 08-07-2011, 13:32   #1 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,950
MXKEY v3.5 revision 1.3 - MEGA UPDATE - The only NOKIA BOX with TMA included
BUY ORIGINAL XTC CLIP
SPECIAL PRICES IN USD with FREE SHIPPING
v3.5 revision 1.3, Public-Release
MEGA UPDATE
What is new added, changes and improvements:
- added USB STANDALONE security repair function *** for ALL HASH for RAPUYAMA phones.
( required HTI with firmware 00.17 )
- added USB STANDALONE security repair function *** for ALL HASH for RAPIDO phones.
SX4AUTH (PA_SL/PA_SL2/PA_SL3/PA_SIMLOC30)
SD REPAIR (PA_SL/PA_SL2/PA_SL3/PA_SIMLOC30)
SIMLOCK REPAIR (PA_SL/PA_SL2)
NCK CALC (PA_SL/PA_SL2)
SL3 BF HASH CALC (PA_SL3/PA_SIMLOC30)
SL3 NCK CALC (PA_SL3/PA_SIMLOC30)
- added: SL3 Logger (sl3u.exe - Standalone SL3 Logger/Unlocker/LOG Converter)
Optimized for SL3 unlock task using HTI or USB cable.
- added: SL3 Bruteforce (sl3bf.exe) 'load at windows startup' option.
- added, notification messages for important function
- added, optional screen recorder
using separated application "camcl.exe", use "Record Session" on system menu
(right click window titlebar)
captured videos will be saved as "capture.avi" in the windows temp folder
will be usefull for reporting bug or something else
- added: connection status/speed information on connect
- moved "[BB5,USB]Use New Protocol for RAPIDO" option to config->Directory
If enabled, will use new loader else will use old loader(embedded to MCU file)
RAPIDO phones with New Protocol connected to HS(High-speed) USB allows to use CERT backup/restore.
Old RAPIDO and RAPIDO connected to non HS USB will not backup CERT due to USB limitation.
NEW ADDED
- added: model selection by type designator or phone description
- added, fw version check between connected phone, mcu image, server during 'Scan Phone'
- added, fw version check between selected mcu image and server during 'market select'
- added, "Copy All Links" on Nokia Download Window
- added, auto complete on Model selection
- added: more detailed description of errors if an error occurs
- added: "[BB5]Use New Protocol for RAP3Gv3" option to config->Directory
- added: phone`s image load from server(if any).
- added: latest firmware version check(if any) for BB5 phone on market select.
- added update dialog window when HTI firmware outdated.
BUG FIXED:
- bugfixed: Nomadik dead usb flashing (Bootstrap failed)
- bugfixed: RAP3Gv3 dead usb flashing (stop at sending bootloader)
- bugfixed: usb3 connection status query
- bugfixed: XGOLD 213 "Use Embedded SBL from MCU" does not work if BB5 selected in generation dropdown.
- bugfixed: access violation on synchronize files when Download window opened.
- bugfixed: application crash on load in some os(win7 x86 no sp).
- bugfixed: XGOLD213 usb flashing error when no mcu spesified
- bugfixed: SL3 read PhoneIDs shows 'Operations not supported'
- bugfixed: X1-01 XGOLD flashing bug.
- bugfixed: No progressbar on flashing.
- bugfixed: New RAPIDO SL3 read PhoneIDs shows 'Operations not supported'
- bugfixed: processing file with size more than 900MB.
- bugfixed: emulate phone on New Protocol causing application to be hang.
- bugfixed: random crash on buscheck with usb connection
- bugfixed: dead after flashing in NOR flash devices (affected on x64 pc with memory more than 4GB)
OTHER CHANGES IN IMPROVEMENTS
- Renamed 'Image DL' caption to 'Download' as this will be easier to understand
- 'Download' will show input dialog if no product code spesified
- local rfbb will also handle rfbb file format
- local dcc will also handle pm file format
- changed FlashLoader selection from dropdown to checklist as this will be more user friendly.
- changed SoftTMA to slider as this will be more user friendly.
- Some UI changes
Add fading on loading module using balloon hint instean of ordinary hint
- changed manifest of mobileEx.exe, SL3 Bruteforce (sl3bf.exe) from 'asInvoker' to 'requireAdministrator'.
Library and modules will need to update their xml configuration files regularly,
or create if xml configuration is not exists. This operation required admin level on vista and win7 core.
- to not confuse users, Nokia USB ROM is now displayed only when no physical NMWCD* device connected
for dead usb flashing, Nokia USB ROM should be used instead of 'Phonet' device
* NMWCD: Nokia Mobile Wireless Communication Devices
- improved auto enable RAPIDO "FUR Cold Boot" by usb hub information
- improved synchronize files routine, auto retry when download failed.
- improved GetFlashAddress and Custom Erase function
(not pooling phone after operation)
- improved *.default(config update) file handling
- removed experimental "run in main thread" bug caused app hang
- usb flashing routine improved
- usb connection handling improved
420 Links to download MxBox/MxKey v3.5 rev1.3 for FREE
1. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
2. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
3. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
4. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
5. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
6. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
7. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
8. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
9. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
10. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
11. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
12. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
13. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
14. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
15. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
16. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
17. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
18. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
19. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
20. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
21. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
22. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
23. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
24. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
25. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
26. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
27. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
28. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
29. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
30. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
!!! MXKEY CABLES - LED SERIES !!!
17 pcs SL3 cables in 1 SET, 44 phones supported
MXKEY CABLES - LED SERIES - 17 pcs cables in 1 SET, 44 phones supported (WORLD FIRST) - GSM-Forum
11 pcs SL3 cables in 1 SET, 15 phones supported
MXKEY CABLES - LED SERIES - 11 pcs cables in 1 SET, 15 phones supported (WORLD FIRST) - GSM-Forum
BR,
Manole
GSM: +8613077861111
ICQ: 66-11-11
YM: manole4000
QQ: 2590331709
MSN: [email protected]
SONORK: 100.88888
Web Page: Manole
The Following 417 Users Say Thank You to MANOLE For This Useful Post:
Old 08-07-2011, 13:55   #2 (permalink)
sankhla871's Avatar
Member: 1438538
Thanks Meter: 37
Thx sir good update ;happy friedship day.
The Following User Says Thank You to sankhla871 For This Useful Post:
Old 08-07-2011, 13:56   #3 (permalink)
mr_loverman's Avatar
Member: 87722
Thanks Meter: 109
great update. keep up.
The Following 2 Users Say Thank You to mr_loverman For This Useful Post:
Old 08-07-2011, 13:57   #4 (permalink)
ravi mobile's Avatar
Member: 669673
Thanks Meter: 300
very good for mx box users .
Thanks Manole Sir and all MX Team.
The Following User Says Thank You to ravi mobile For This Useful Post:
Old 08-07-2011, 14:00   #5 (permalink)
Member: 79442
Thanks Meter: 8
thanks for this nice and good update...i hope this fixes all the bugs in previous version... Long Live MXKEY!!!
The Following User Says Thank You to mhikeguese For This Useful Post:
Old 08-07-2011, 14:00   #6 (permalink)
Member: 1587225
Sonork: 100.1605724
Thanks Meter: 6
useful for mxbox user
nice update
thanx
Old 08-07-2011, 14:01   #7 (permalink)
Danish Shafiq's Avatar
Member: 1118710
Sonork: 100.1604414
Thanks Meter: 4,965
Thanx For Nice Update Manole...
The Following User Says Thank You to Danish Shafiq For This Useful Post:
Old 08-07-2011, 14:01   #8 (permalink)
Registered User
Member: 1592655
Thanks Meter: 214
good update thank you
Old 08-07-2011, 14:02   #9 (permalink)
..::khaled::..'s Avatar
Member: 329483
Thanks Meter: 443
what about unlock by usb !!!!
Old 08-07-2011, 14:03   #10 (permalink)
pradeep_kus's Avatar
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,459
what about mxkey server ? always down
when we do supersdauth
or dct4 rpl
Old 08-07-2011, 14:05   #11 (permalink)
Registered User
Member: 1185007
Thanks Meter: 25
Good update
Great Work MxBox Team
Good Update Every time
Thanks Manole
Old 08-07-2011, 14:06   #12 (permalink)
.::VENUGOPAL::.'s Avatar
Member: 1230663
Sonork: 100.1593487
Thanks Meter: 174
nice update keep it .thank to mx team
Old 08-07-2011, 14:11   #13 (permalink)
Cheater -Don't Deal with him-
Member: 1294693
Sonork: 100.1591739
Thanks Meter: 483
thanx for big update..but,pls keep servers online
The Following User Says Thank You to gsmdocter For This Useful Post:
Old 08-07-2011, 14:11   #14 (permalink)
Member: 931356
Sonork: 100.1638784
Thanks Meter: 17
this is the best gift to give ur professional frnds thnxxxxx for update
Old 08-07-2011, 14:12   #15 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 732
Thumbs up mxkey & mx box
Great. Very Good Update.
The Following 2 Users Say Thank You to .::Gsm-Play::. For This Useful Post:
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 03:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.54966 seconds with 10 queries
