Old 10-08-2011, 21:31   #1 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,942
MXKEY v3.5 revision 1.4 - HTI v00.24 firmware accept SL3instant unlock activations
BUY ORIGINAL XTC CLIP
SPECIAL PRICES IN USD with FREE SHIPPING
MXKEY/MXBOX v3.5 revision 1.4, Public-Release
MEGA UPDATE
What is new added, changes and improvements:
MAIN
1. introduced HTI Firmware version 00.24
new in firmware:
- firmware accept SL3instant unlock activations for MXBOX
- bugfixed: BB5 security repair algorithm for RAPIDO new ASIC
- implemented WD2 and BTMCM flashing protocol
- implemented TIKU and MM(NAND) flashing protocol
please Update HTI by using "Update HTI" button or "HTIUpdate.exe"
2. improved: antivirus compatibility.
3. improved: daily update check routine.
4. improved: built-in downloader routine
- added: resume support
- bugfixed: handing big file size(more than 1G)
5. added: support for upcomming windows 8(windows developer preview) support.
6. added: Detailed 'LastError' message window when No Security Dongle Detected
7. added: Detailed HTI identity(boot & fw version, serial) on connect.
New Application released:
MXKEY - Fire Agent(fire.exe)
it's brand new support tool and firmwares download support client
1. Using shared configuration with corresponding module,
simplify the needs to download/update firmware file.
2. Working in sync mode with modules for better usage.
3. using built-in downloader with resume support.
Supported services:
1. Nokia firmware, along with latest firmware notification info
2. CDMA firmware, various vendor(Alcatel, Haier, Huawei, LG, Nokia, ZTE)
3. more services to be added at the future
Nokia Tool
- important informations (Asic ID, ROOT KEY HASH, UEM Imei) now highlighted (beginner friendly).
- added: BB5 security repair function for RAPUv2 phones (beta testing)
- added: Verify Secure Data at 'Read SL3 Hash'/'Read Phone IDs',
(used to verify if secure data readed from the phone is valid to make sure
the hash readed by software(both USB/FBUS) is 100% correct)
- added: "Fire Support" menu in module`s options.
- added: support to load variant definitions created by fire.exe
- added: Spesified window dialog when card is busy/used by other module to fire.exe, sl3u.exe.
- added: support to convert log to other third party format to SL3BF module (sl3u.exe)
- added: new definition to 'phoneIdentity.ini.default'
- added: flash loader version 11.24.000.3 to setup
- added: RPL backup list load at scan (used for "Write Rpl' with 'Use RPL file' ticked)
- added: PM backup list load at scan
- improved: module initialization.
- improved: 'phone definitions loading' at first load.
- improved: 'HTI Auto BSI(SoftTMA)' set.
- improved: file/image version check routine.
- improved: Reboot after flash mode
- improved: WD2 flashing with HTI
- bugfixed: BTMCM flashing bug with HTI
- bugfixed: No Security Dongle Detected when HTI connected with phone
(HTI power switched off on load)
- bugfixed: RAPIDO New Asic security repair function
CDMA Tool
USE MxBox/MxKey v3.5 rev1.5
MXKEY/MXBOX v3.5 revision 1.5, Public Discussion Thread
!!! MXKEY CABLES - LED SERIES !!!
17 pcs SL3 cables in 1 SET, 44 phones supported
MXKEY CABLES - LED SERIES - 17 pcs cables in 1 SET, 44 phones supported (WORLD FIRST) - GSM-Forum
11 pcs SL3 cables in 1 SET, 15 phones supported
MXKEY CABLES - LED SERIES - 11 pcs cables in 1 SET, 15 phones supported (WORLD FIRST) - GSM-Forum
BR,
Manole
GSM: +8613077861111
ICQ: 66-11-11
YM: manole4000
QQ: 2590331709
MSN: [email protected]
SONORK: 100.88888
Web Page: Manole
The Following 592 Users Say Thank You to MANOLE For This Useful Post:
Old 10-08-2011, 21:40   #2 (permalink)
slim2's Avatar
Member: 120374
Thanks Meter: 37
thank' Mr.Manole goooooooooooooood news and gooooooooooooood work .
The Following 3 Users Say Thank You to slim2 For This Useful Post:
Old 10-08-2011, 21:53   #3 (permalink)
LOUAI2005's Avatar
Member: 192230
Thanks Meter: 106
hi ...............................
I can definately claim you are the best and the first in nokia
I'm happy using your products
The Following 3 Users Say Thank You to LOUAI2005 For This Useful Post:
Old 10-08-2011, 21:57   #4 (permalink)
Member: 192963
Thanks Meter: 26
The Following 2 Users Say Thank You to ayman122 For This Useful Post:
Old 10-08-2011, 22:01   #5 (permalink)
Cheater -Don't Deal with him-
Member: 686535
Sonork: 1592667
Thanks Meter: 108
direct unlock?????.....................
The Following User Says Thank You to roklat For This Useful Post:
Old 10-08-2011, 22:06   #6 (permalink)
..::khaled::..'s Avatar
Member: 329483
Sonork: 100
Thanks Meter: 443
firmware accept SL3instant unlock activations for MXBOX ???????!!!!!!!!!!!!!!!!!!!!
The Following User Says Thank You to ..::khaled::.. For This Useful Post:
Old 10-08-2011, 22:08   #7 (permalink)
sokolibrahimi's Avatar
Member: 239956
Thanks Meter: 68
what's this sl3instant activation is this direct unlock or what there will be dead maket!!!!!!!!!!!
The Following User Says Thank You to sokolibrahimi For This Useful Post:
Old 10-08-2011, 22:09   #8 (permalink)
leonirvana's Avatar
Member: 290434
Sonork: -
Thanks Meter: 39
Question
what do u mean ??????????
Old 10-08-2011, 22:10   #9 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Dead market for who ? For Brute Force Servers ?
BR,
Manole
The Following 25 Users Say Thank You to MANOLE For This Useful Post:
Old 10-08-2011, 22:15   #10 (permalink)
Member: 239956
Thanks Meter: 68
yes this i good new but can you explain it more
Old 10-08-2011, 22:19   #11 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
BR,
Manole
whats you mean brother byby bruteforce ? you have solution for direct unlock?
The Following User Says Thank You to yassinek85 For This Useful Post:
Old 10-08-2011, 22:21   #12 (permalink)
hassanjinja's Avatar
Member: 126167
Sonork: 100.1591387
Thanks Meter: 5,129
@ sokolibrahimi
Agree with You, Be specific
Does This Mean, Need Another activation for Instant sl3 direct unlock, apart from The sl3 activated ( by Ivan Glov) solutions
HASSAN
The Following User Says Thank You to hassanjinja For This Useful Post:
Old 10-08-2011, 22:22   #13 (permalink)
Member: 21296
Thanks Meter: 328
Nothing just bla-bla and some bugfixes....
The Following User Says Thank You to byteforce For This Useful Post:
Old 10-08-2011, 22:30   #14 (permalink)
Member: 630387
Thanks Meter: 6
error when trying update sir ,,, what problem this ???
The Following 2 Users Say Thank You to Jefrey For This Useful Post:
Old 10-08-2011, 22:33   #15 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
What error ?
I write so many times, post picture and more details when you have errors.
BR,
Manole
The Following 15 Users Say Thank You to MANOLE For This Useful Post:
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.23750 seconds with 10 queries
