Old 02-18-2010, 01:33   #1 (permalink)
Member: 706822
Thanks Meter: 647
mxkey windows 7 drivers pls
mxkey windows 7 drivers pls 32/64 bit pls pls pls manole
The Following 2 Users Say Thank You to mathew_di For This Useful Post:
Old 02-18-2010, 01:52   #2 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
you have all in your coputer
go to C:\mobileEx\3.3\data\drivers\card
The Following User Says Thank You to yassinek85 For This Useful Post:
Old 02-18-2010, 02:15   #3 (permalink)
SilentHawk's Avatar
Member: 444805
Thanks Meter: 45
goto control panel and click device manager then update driver and follow the instruction
windows 7 compatible in mxkey 101%
The Following User Says Thank You to SilentHawk For This Useful Post:
Old 02-18-2010, 05:11   #4 (permalink)
DaWizard's Avatar
Member: 61557
Thanks Meter: 130
no need to install the driver for the card. It will work try to run the software and it will be ok. tested by me
The Following User Says Thank You to DaWizard For This Useful Post:
Old 02-18-2010, 06:31   #5 (permalink)
Member: 1011547
Thanks Meter: 342
they all are saying crap i have the same problem now mx key is working fine.. you better follow this procedure
install mx exe after installiation left click mx icon go in find target then driver,card,ft2k,in this folder you will find rockey driver exe install it reboot your problem is sloved >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
The Following 2 Users Say Thank You to mani2050 For This Useful Post:
Old 02-18-2010, 12:37   #6 (permalink)
Member: 706822
Thanks Meter: 647
problem mxkey windows 7---driver pls manole
The Following User Says Thank You to mathew_di For This Useful Post:
Old 03-03-2010, 05:06   #7 (permalink)
chip_2000's Avatar
Member: 22400
Thanks Meter: 44
No use USB HUB!!!! Put Smarcard Reader USB 2.0!! For me work fine/!!!
The Following User Says Thank You to chip_2000 For This Useful Post:
Old 03-14-2010, 05:09   #8 (permalink)
Member: 1090690
Sonork: chanchal
Thanks Meter: 14
my mx-key does not compatible with windows 7
i need its driver
The Following User Says Thank You to marbin For This Useful Post:
Old 03-14-2010, 05:18   #9 (permalink)
Member: 823633
Thanks Meter: 1,705
bro here driver
http://forum.gsmhosting.com/vbb/f550...urgent-934431/
The Following 2 Users Say Thank You to vaghubha_sodha For This Useful Post:
manole pls mxkey windows 7 mathew_di MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 08-02-2010 20:45
Pls halp windows 7 drivers...? syedarif JAFWM 0 03-19-2010 11:26
windows 7 driver newerno Z3X-Team Products 2 12-22-2009 14:18
windows 7 driver dadang.haryadi CPF-BOX Ⅱ 2 10-14-2009 14:23
Page generated in 0.19197 seconds with 10 queries
