10-13-2009, 13:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Mobile phone world
Member: 90701 Status: Offline Thanks Meter: 134 | My Card is activated with limited activities |
10-14-2009, 16:46 | #6 (permalink) | |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Quote:
What is your serial number of mxkey ? What windows you are using ? Can you give us screen shot ? BR, Manole | |
10-14-2009, 17:14 | #7 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | Quote:
just go to imei ans security area and select simlock and tick init simlock/repair sl if in these process your problem not solved then backup rpl and then make reset npc and again restore rpl ,sx4and pm | |
10-14-2009, 19:17 | #9 (permalink) | |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Quote:
Got it today, use it for the first time to repair a 6267 killed by cyclone. Register today Serial: C0803949 FW version: 00.20 Counter remain: 99,93% Licenses: 0 = True 1 = True 2 = True - Registered to: hugmax using Windows XP SP3 with all the .net frameworks installed | |
10-17-2009, 12:05 | #15 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Where Dreams Comes True...S4U
Member: 755709 Status: Offline Sonork: 100.1592000 Momo... Thanks Meter: 6,635 | getting:Card is activated with limited activities just with jaf as interface but ufs give not this msg but its working you can unlock and flash with without any troubles they are the same. |
Module activated with limited support! with ver: 3.3:1.6 | Unicom | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-14-2010 09:07 |
Module activated with limited support | Deepakranasaria | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 12-11-2009 08:36 |
Module activated with limited support! | ak72342 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 12-11-2009 08:28 |
Module activated with limited support! | adnanskyland | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 10-18-2009 11:44 |
Module activated with limited support! | R@ZIB-BD | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 09-01-2009 10:14 |
