02-05-2013, 09:00 | #1 (permalink) |
Registered User Join Date: Jun 2011
Member: 1597393 Status: Offline Sonork: 6692766 Thanks Meter: 4 | Nokia 5233 not booting after flash SET IS DEAD ONLY VIBRATE. HERE IS LOG MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000DB7B Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: A0923FB6_RM-625_51.9.002_prd.core.C00 [BB5,XSR 1.6] size: 95.02 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 13A00117F6A300526C224B911E97C7E3103990FC CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 1 min 25.141 s Processing PPM file: F3740A37_RM-625_51.9.002_prd.rofs2.V25 [BB5,XSR 1.6] size: 26.50 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 35.50 MB CMT FLASH,MuxOneNAND area [06DE0000-0915FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 24.640 s Processing CNT file: RM625_51.1.002_000_001_U002.uda.fpsx [BB5,XSR 1.6] size: 14.88 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Flash programming ... Programming completed in 15.047 s Total time for flashing process(boot+erase+write) was 2 min 15.094 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1ED68E41 Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Aborting operation ... Warning: Phone did not reboot to normal mode. |
02-05-2013, 09:08 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Use Quick Fix Method, Go to Service Tab > Quick Fix Tab > Tick BB5 Rap3NAND ERASE & Click Do Selected Job, Will solve your Problem, If not Solve, then try to Erase Phone from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ Before Erase Check whether all necessary Backup has been taken, Download Latest Flash Files of Same Product Code & Flash it. BR, ZUBER |
