08-16-2012, 13:38 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: lalamusa pakistan Age: 39
Member: 1724303 Status: Offline Sonork: 1611265 Thanks Meter: 70 | my nokia C 2-03 damage with mx i try to rest life timer after this phone go on contact serves sl data not fount please mx teem tell me what is this with your box problem normal set is 50% dead |
08-16-2012, 14:11 | #3 (permalink) |
Member: 1724303 Status: Offline Sonork: 1611265 Thanks Meter: 70 | Phone type: RM-702 (C2-03) SW version: V 07.57 22-06-12 RM-702 (c) Nokia Imei plain: 35932404079864-8 Product code: 059D475 Battery voltage: 3868 mV, current: 101 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MH1 Language Pack: - not available. Camera config: 06150123007025, ver: SIMLOCK_DATA corrupted! |
08-17-2012, 05:26 | #10 (permalink) |
Member: 1724303 Status: Offline Sonork: 1611265 Thanks Meter: 70 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0**** Using device: USB ROM and HTI, FW ver: 00.50, SN: 000**** Connection status: UHCI:HUB:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-03 USB Phonet, PORT_ID: 185219CA Verifying communication to device OK. Phone type: RM-702 (C2-03) SW version: V 07.57 22-06-12 RM-702 (c) Nokia Imei plain: 35932404079864-8 Product code: 059D475 Battery voltage: 3838 mV, current: 102 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MH1 Language Pack: - not available. Camera config: 06150123007025, ver: SIMLOCK_DATA corrupted! |
08-17-2012, 05:36 | #11 (permalink) |
Member: 1724303 Status: Offline Sonork: 1611265 Thanks Meter: 70 | flash loog Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Battery voltage: 3823 mV Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35932404079864 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK LOCK120_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35932404079864_ back.RPL" Processing file: rm702__07.57.mcusw Downloading item CODE:rm702__07.57.mcusw_ebl_psi.fls, num block: 4, size: 28 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.390 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.375 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.562 s Erasing area 0x40280000-0x41D3FFFE ...OK Programming completed in 34.110 s Checksum verified (0xCE42) Processing file: rm702__07.57.ppm_mh1 Downloading item CUSTackage_mh1.ppm_ebl_psi.fls, num block: 1, size: 4.86 MB Erasing area 0x41DC0000-0x4229B14A ...OK Programming completed in 6.828 s Checksum verified (0xDA8F) Processing file: rm702__07.57.image_mh1_059P4Z1 Downloading item CUSTackage_mh1_059P4Z1.image.fls, num block: 1, size: 13.88 MB Erasing area 0x424C0000-0x43E1FFFE ...OK Programming completed in 21.516 s Checksum verified (0xC2DB) Total time for flashing process(boot+erase+write) was 9 min 18.766 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-03 USB Phonet, PORT_ID: 185219CA Verifying communication to device OK. Phone type: RM-702 (C2-03) SW version: V 07.57 22-06-12 RM-702 (c) Nokia Imei plain: 35932404079864-8 Product code: 059D475 Battery voltage: 3808 mV, current: 106 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MH1 Language Pack: - not available. Camera config: 06150123007025, ver: SIMLOCK_DATA corrupted! |
08-18-2012, 15:14 | #15 (permalink) |
Member: 1724303 Status: Offline Sonork: 1611265 Thanks Meter: 70 | My problem will be silved . . . . Operating mode is OK, no need change... Field 4 Record 1 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 9 write - Ok Record 18 write - Ok Record 19 write - Ok Record 26 write - Ok Record 28 write - Ok Field 120 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 308 Record 1 write - Ok Done! Elapsed: 00:00:00 Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:11 Reading Phone Info.... Connected phone - C2-03 Software ver : V 07.57 22-06-12 RM-702 (c) Nokia IMEI 1 : 359324040798648 IMEI 2 : 359324040798655 PPM : V 07.57 22-06-12 RM-702 (c) Nokia MH1 CNT : Content: mh1_059G937 V 07.57 22-06-12 RM-702 (c) Nokia Product SN : 4EEA90BAH Product code : 059D475 Base Prd.code: 059D007 Module code : 0204579 Long Prod.SN : 0 Hardware info======= HWID : 1000 Batery: 3763 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 359324040798648 IMEI spNet : 3A 95 23 04 04 97 68 04 IMEI svNet : 33 95 23 04 04 97 68 24 F0 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 5834AED556A7CCCD Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created INFINEON : SuperDongle not exist (It is Ok) SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Set phone in Normal mode... Restarting... Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok can you tell me that how you solve it? |
