07-02-2011, 13:44 | #2 (permalink) | |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | Quote:
Downloads and documentation [IMG]file:///C:/DOCUME%7E1/IRFANA%7E1/LOCALS%7E1/Temp/msohtml1/01/clip_image001.jpg[/IMG] Download Flasher-3.5 and Install: http://tablets-dev.nokia.com/maemo-d...-downloads.php Download Flash Files: tablets-dev.nokia.com restricted downloads and save it here: 'c:\Program Files\maemo\flasher-3.5\' Make sure N900 at leat 50% charged, you dont want it to die half way. 1 . N900 must not be connected to the cable yet, oK. Turn it oFF. 2. Hold "U" key on the N900 QWERTY keyboard and connect it to the USB cable. 3. Once you see the NOKIA Logo and USB cable on phone Screen, let go of "U" key. 4. Goto start> run> and type "cmd" 5. In the black command window, type/copy "cd c:\program files\maemo\flasher-3.5" 6. Then type/copy: flasher-3.5.exe -F RX-51_2009SE_3.2010.02-8_PR_COMBINED_MR0_ARM.bin -f 7. When CMT flashed successfully done, now we hve to Format this phone to fix the actual problem "Not enoug memory", type/copy: flasher-3.5 -F RX-51_2009SE_1.2009.41-1.VANILLA_PR_EMMC_MR0_ARM.bin -f -R 8. This will delete ALL content on your 32GB mass memory and replace back all the ORIGNAL content that comes with N900 by default, everything will be good and fresh this method helped me to get my instalation memory back. Orignal Link with full detail is here: https://wiki.maemo.org/Updating_the_tablet_firmware | |
08-20-2011, 09:17 | #3 (permalink) | |
Junior Member Join Date: Apr 2008
Member: 758772 Status: Offline Thanks Meter: 0 | nokia n900 unlock Quote:
i can't download maemo flasher file from the given URL | |
08-24-2011, 21:04 | #5 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1640881 Status: Offline Thanks Meter: 0 | n900 memory low it is a hardwre falt.. remove the camera.. and mmc holder plastik black braket. after that re solder mass memory i c.dont heat too much. use 350c on ur (hot aire gun). after fix the camera and mmc braket.. check it don.. cooool.. good luck. (shamee) |
11-03-2011, 16:26 | #8 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | please can you be more explicite? what is EMMC file and where to get it? i flash my N900 but it still show me that there is no space for install applications i can't even to defaults restore as code 12345 when enter to reset say wrong code. i use even another box to reset that code but still wrong code. so how to wipe all memory |
v66/t191 are they 900/1800 | F C | Motorola P2k | 1 | 01-16-2002 16:24 |
AMD Duron 900 for dark flasher | foneman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-05-2001 23:15 |
GF768 - 900 or 1800mhz??? | dbatman | Old Ericsson Phones & Sony Phones | 1 | 03-30-2001 13:34 |
NEED ANYTHING, SOFTWARE, RINGTONES, 900 NOLīS | jonthe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-27-2000 03:10 |
