Old 02-10-2010, 08:07   #1 (permalink)
Member: 524163
Sonork: 1589680
Thanks Meter: 31
N-91 Security Test Failed
After Scan -
Phone Type: RM-43 (Nokia N91-1)
SW Version: V w33_07w11v1 14-03-07 RM-43 (c) Nokia.
Imei plain: 12345610654321-?
Product Code: 0523189
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei plain is invalid !!!
Imei net: 12345610654321?
Version: SIMLOCK SERVER VERSION 62
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
After Bus Check -
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 489AD5650DA63CEBDEC77EA3E11073F00E036B56
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM0 ID: 00000232
EM1 ID: 00000352
PUBLIC ID: 15200212D7654E513327B3F854FF0ACF723C7095
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE
ALG [35]: OMAP1710 UNISTORE-II-1.2.1 ALG
ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 6E25F5B4407C1CBD0598994502C24000F3657C18
Original Imei: 35835300xxxxxx
Original Product code: 0523189
BACKUP RPL is also saved with same IMEI Number. Please help me in this matter.
Old 02-10-2010, 08:27   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
there are 2 kind N91 and N91 8GB
both have code RM-43
but different in frimware version.
DONT ERASE, BACKUP YOUR RPL DATA.
IF N91 then FLASH with LOWER version ( v 2.20 or lower)
IF N91 8GB Flash with HIGHER version (v 3.0 or higher )
br,
Old 02-10-2010, 08:29   #3 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
try this solution i think we help your problem
MXkey Tips and Tricks - HOT SOLUTION ONLY HERE
Old 02-10-2010, 11:26   #4 (permalink)
Member: 524163
Sonork: 1589680
Thanks Meter: 31
br,
Sir, i've flashed with V3.10.023 files, how can i restore IMEI ?
Bus Check
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Original Imei: 35835300337063
Backup RPL
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0xB8 bytes).
Reading RAP CCC (0x0 bytes).
Reading RAP HWC (0x0 bytes).
Reading APE NPC (0x0 bytes).
Reading APE VARIANT (0x0 bytes).
Reading APE CCC (0x0 bytes).
Reading APE HWC (0x0 bytes).
Flash Imei: 35835300337063
NPC_DATA saved OK
VARIANT_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35835300337063_BA CK2.rpl"
After Scan
Phone Type: RM-43 (Nokia N91-2)
Product Code: 0535354
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Phone is having " PHONE STARTUP FAILED PLEASE CONTACT THE RETAILER "
Old 02-10-2010, 11:28   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
have u read this
or must have bigger size ?
br,
Old 02-10-2010, 12:16   #6 (permalink)
Member: 524163
Sonork: 1589680
Thanks Meter: 31
have u read this
br,
Thanx Sir, My problem solved.
N73 security test fail start up fail mobile_mania MXKEY Nokia Flasher and Unlocker (by Alim Hape) 31 03-14-2013 20:33
succes full repair phone startup failed and security test failed jagdish puri MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-12-2010 14:17
Success two security TEST failed but faile in one 5220 FAILE khokonhajigonj MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-09-2010 15:38
3110C security test fail after sd repair now tested ok GSMaxx MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-06-2010 11:19
Please HELP security test -Failed rakishi Universalbox 0 01-18-2007 23:45
Page generated in 0.33488 seconds with 8 queries
