02-23-2010, 18:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brazil Age: 41
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | n-95 8g dead after unlock!! I make the release of 2 n95 rm-421 by mxkey! the release executed successfully put the aircraft was restarting. noticed the superdongle it was corrupt and he was with the security test fail. did the procedure described by the mobility eg BECKUP rpl (rap) erase flash restore imei repair sl repair sd write pm the apparatus was left with all the information right, but he does not connect and when he shot the machine goes off again, tried by UFSX (using it as an interface with the mxkey) and the jaf (using an interface with the mxkey). but it is always display the blue and does not connect! could someone help me please ........ are two devices and they are very expensive here in my country! this is his log: Phone Type: RM-421 (Nokia N95 8GB) SW Version: V 06wk41v64.19 01-10-09 RM-421 (c) Nokia Imei plain: 35294602311478-6 Product Code: 0557135 Language Pack: - Not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Net Imei: 352946023114786 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0 / 3, 0 / 10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 2: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 3: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 4: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 5: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 6: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 7: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF and this is the other: APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Reading RAP NPC (0x1B8 bytes) Original Product Code: 0566083 Reading RAP VARIANT (0x0 bytes) VARIANT empty ! Reading RAP CCC (0x160 bytes) Product Code: 0559492 Product Code missmatch ! Reading RAP HWC (0xD4 bytes) Product Code: 0566083 HWC seems to be valid |
The Following User Says Thank You to Bruno Rafael For This Useful Post: |
02-23-2010, 19:34 | #3 (permalink) |
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | I press the power button it vibrates illuminates the keyboard and the screen goes dark and he did not leave this to the screen is dark without light and caught !!!!! |
02-23-2010, 19:43 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | 1st.need reflash with ENO frimware try find on this thread ALL NOKIA LATEST version and ENO Firmware !! 2nd.repair SECURITY_TEST failed! do "SUPER SD AUTH" and write PM [1] and [309] if not lucky , try with rebuilt RPL contain CCC and HWC data from this thread [MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, ps : next please do unlock with NCK code calculator, that is safety one |
05-01-2010, 23:42 | #9 (permalink) |
Freak Poster Join Date: May 2008 Location: kingston 111a molynes road
Member: 767332 Status: Offline Sonork: nickardo Thanks Meter: 22 | n95 8g rm320 done by mx-key v3.3 1.8 just calculate code here is the screen shoot Product: V 06wk41v51.3 13-02-08 RM-320 (c) Nokia ApeCoreSw: 20.0.016 Using cached productData[1480010706C100586271C6AF4AF80E8458C84450] ... Calculating NCK using security server ... #pw+ 661332773893484 +1 # #pw+ 340141364883317 +2 # #pw+ 020010676844237 +3 # #pw+ 142059253684765 +4 # #pw+ 404580048947038 +5 # |
Nokia 2720 dead after unlock | unlocklleida | Cyclonebox | 3 | 03-31-2010 17:25 |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
n-95 8g dead after unlock!! | Bruno Rafael | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-23-2010 19:47 |
nokia n81 8g dead After Took rong pm | karamfone | Nokia Base Band 5 ( BB-5 ) | 15 | 12-14-2008 19:00 |
n95-8g dead after format | moez.mobileline | Infinity-Box | 1 | 08-23-2008 21:07 |
