08-07-2009, 14:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: South Africa
Member: 340957 Status: Offline Thanks Meter: 65 | N70 flashing error APE Data : SYSTEM ASIC ID: 17100701 [OMAP1610 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 86E3926772A4F321FB4BF6C996CD4B0F45A803D3 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM1 ID: 00000232 EM2 ID: 00000352 PUBLIC ID: 098001183D944951443C0C8732A91CD2CA344148 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D rap3gv2_2nd.fg: [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D helen3_2nd.fg: [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 RX2 enabled. FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 h3_sam_nand_gbbm.fg: [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS ID: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Reading RAP NPC (0x168 bytes). Reading RAP VARIANT (0x4F0 bytes). Reading RAP CCC (0x0 bytes). Reading RAP HWC (0x0 bytes). Reading APE NPC (0x0 bytes). Reading APE VARIANT (0x0 bytes). Reading APE CCC (0x0 bytes). Reading APE HWC (0x0 bytes). Flash Imei: 35936700426988 NPC_DATA saved OK VARIANT_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.2\data\backup\RPL\BB5_3593670042698 8_back.rpl" Processing file: rm84_50638301.c0 APE Data : SYSTEM ASIC ID: 17100701 [OMAP1610 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 86E3926772A4F321FB4BF6C996CD4B0F45A803D3 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM1 ID: 00000232 EM2 ID: 00000352 PUBLIC ID: 098001183D944951443C0C8732A91CD2CA344148 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D rap3gv2_2nd.fg: [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D helen3_2nd.fg: [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 RX2 enabled. FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 h3_sam_nand_gbbm.fg: [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS ID: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Programming MCU ... rm84_50638301.c0: [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.40 MB Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported APE Ids: 17100701, 17100702 Total erase size: 68.92 MB CMT NOR area [00000000-0052B2E9] erased in 36.531 s CMT NOR area [006A0000-006BFFFF] erased in 1.391 s CMT NOR area [006DF000-006EFFFF] erased in 1.391 s CMT NOR area [00700000-007EFFFF] erased in 6.828 s APE NAND area [00000000-0000FFFF] erased in 0.062 s APE NAND area [00010000-0001FFFF] erased in 0.063 s APE NAND area [00020000-000203FF] erased in 0.047 s APE NAND area [00050000-03ECFFFF] erased in 7.000 s Flash programming ... Valid PAPUB key found, CMT PAPUBKEYS, Rap certificate3 written. Valid PAPUB key found, APE PAPUBKEYS, APE certificate3 written. Error while programming [01] at 0x00F28000, Result: 0000 Flashing terminated with error(s) in 4 min 27.547 s RX Buffer: B372 |
08-08-2009, 20:31 | #6 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
but if u have the complete old backup of your phone before unlocking then i think it can be repaired ... | |
Nokia N70 Flashing Error | fusion007 | Universalbox | 36 | 11-01-2010 14:22 |
