05-06-2011, 12:06 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 581888 Status: Offline Thanks Meter: 74 | n70 flashing error (ANSWERED) Processing MCU file: RM84_50737301.C0 [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100701, 17100702 Partitioning ...OK Erase size: 68.92 MB CMT NOR area [00000000-0052B515] CMT NOR area [006A0000-006BFFFF] CMT NOR area [006DF000-006EFFFF] CMT NOR area [00700000-007EFFFF] APE NAND area [00000000-0000FFFF] APE NAND area [00010000-0001FFFF] APE NAND area [00020000-000203FF] APE NAND area [00050000-03ECFFFF] erased in 1.375 s Flash programming ... Error 010100009D:E5 Error Sync! Error CAB5990000:F0 Error Sync! Error while programming [00] at 0x00000400, Result: 0200 Task failed at (0800001C)!!! Last RX buffer: CA B5 99 00 00 F0 FF 02 00 00 00 00 F1 72 please give me a solution |
09-06-2011, 08:50 | #4 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Nepal Age: 47
Member: 732075 Status: Offline Thanks Meter: 29 | Hi when i get to flashing N70 get this error from mx-key now set is dead Version from phone: 5.0737.3.0.1 Version from file: 50737301.C0 MXKEY Serial: [FT SCR2000 0] - C080095A Using device: UFS_USB V2.8 (c) SarasSoft 2007. Connection status: UHCI:HUB:HUB:USB 1.10 (Full-speed) Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Reading Important data ... Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35291302238657_BA CK.rpl). APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 7F0F7B7C7728731BE02F41DC596CD0C8DECA8639 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 242001130C6646514B0EAB1173BD8C8A392277BC ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 eBB5ProtocolType: OLD Storage0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 Storage0: 00EC 0036 - 005A 003F [Samsung KAL00R00EM-DGXX,512 Mbits] type: FLASH,NAND, asic:APE Suggested algorithm: OMAP1610 GBBM-1.8.1 ALG Storage content: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Processing MCU file: RM84_50737301.C0 [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100701, 17100702 Partitioning ...OK Erase size: 68.92 MB CMT FLASH,NOR area [00000000-0052B515] CMT FLASH,NOR area [006A0000-006BFFFF] CMT FLASH,NOR area [006DF000-006EFFFF] CMT FLASH,NOR area [00700000-007EFFFF] erased in 43.187 s Prog.status for Asic CMT ... NOR: Success NAND: Success Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0F72BF9D [Rap certificate3] sent APE KEYS block sent APE X-LOADER block sent APE PRIMAPP block sent APE SOS+LOADER block sent APE SOS+XZIP block sent APE PASUBTOC block sent APE PAPUBKEYS: 0F72BF9D [APE certificate3] sent APE SOS*CORE block sent Prog.status for Asic APE ... NOR: Success NAND: Success Programming completed in 3 min 3.453 s Processing PPM file: RM84_50737301.V12 [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 9.76 MB Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100700, 17100701, 17100702, 17100703 Partitioning ...OK Erase size: 35.94 MB erased in 0.109 s Prog.status for Asic APE ... Flash programming ... Error 010100009D:E5 Error Sync! Error CAB5990000:F0 Error Sync! Error while programming [01] at 0x01AE0000, Result: 0200 Total time for flashing process(boot+erase+write) was 4 min 7.844 s Phone type: RM-84 (Nokia N70) SW version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. Imei plain: 35291302238657-5 Product code: 0539240 Battery voltage: 4185 mV, current: 260 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid Imei net: 352913022386575 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.750 s |
09-06-2011, 09:21 | #5 (permalink) |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
