Old 12-12-2011, 06:06   #1 (permalink)
Member: 982335
Thanks Meter: 202
N70 flashing error with latest ver please check.
N70 flashing error with latest ver ....
Version from phone: 05wk07v48.1
Version from file: 50737301.C0
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0803577
Using device: HTI, FW ver: 00.24, SN: 00000FB6
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35808001851618_BA CK.rpl).
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1E90000736416851E391F5596AE4F2FABB7CE942
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
eBB5ProtocolType: OLD
Storage0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
TransmissionMode: DDR&TX2
Processing MCU file: RM84_50737301.C0
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB
Supported Ids: 17100701, 17100702
Partitioning ...OK
Erase size: 68.92 MB
CMT FLASH,NOR area [00000000-0052B515]
CMT FLASH,NOR area [006A0000-006BFFFF]
CMT FLASH,NOR area [006DF000-006EFFFF]
CMT FLASH,NOR area [00700000-007EFFFF]
erased in 39.562 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 0F72BF9D [Rap certificate3] sent
Error chk C7012D0100D0
Error while programming [01] at 0x00000000, Result: 0000
Total time for flashing process(boot+erase+write) was 1 min 17.532 s
Phone type: RM-84 (Nokia N70)
SW version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia.
Imei plain: 35808001851618-7
Product code: 0539276
Battery voltage: 4857 mV, current: 95 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358080018516187
Version: SIMLOCK SERVER VERSION 58
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 12-12-2011, 06:59   #2 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
brother better try on jaf , your problem will be solved mxbox can not flash it
The Following User Says Thank You to sweet4hamza For This Useful Post:
Old 12-12-2011, 07:07   #3 (permalink)
Member: 1695418
wrong, MXBOX is perfect.
i use HTI on everyday service. check cable bot fbus cable and mini usb.
Old 12-13-2011, 09:22   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
OMAP and NAND not booted.
check SMPS chip near keypad spring connector.
Old 11-14-2012, 08:27   #5 (permalink)
Syifa.Cell's Avatar
Member: 624037
Sonork: 100.1608764
Thanks Meter: 41
can upload th picture???
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.18396 seconds with 9 queries
