Old 06-17-2010, 19:00   #1 (permalink)
live14's Avatar
Member: 673661
Thanks Meter: 349
۞ final solution for hang and shut down bb5 sl1 sl2 with mx-key۞
here is the final solution for bb5 sl1 sl2 show nokia and shut down
1- flash with the last version
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 05A0010329E15850D8BC9DDD106F3D7064EB4348
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B
Original Imei: 35571702873940
Original Product code: 0568404
Bluetooth ID: 0021FCF82C54
Phone not responding !
2-after flash if the wort its ok, if the phone not responding after flash do this:
- backup just npc
- go to advance then get address
- uncheck safe erase
- uncheck all erase address except eeprom
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 256.00 KB
CMT NOR area [03FC0000-03FFFFFF] erased in 1.750 s
after erase eeprom do scan
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 06.51 23-03-09 RM-411 (c) Nokia
Imei plain: 35571702873940-7
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
repair simlock
Product: V 06.51 23-03-09 RM-411 (c) Nokia
Using cached productData[05A0010329E15850D8BC9DDD106F3D7064EB4348] ...
Calculating SIMLOCK using security server ...
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0
Completed in 11.532 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-411_355717028739407_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Imei net: 355717028739407
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
repair sd
Calculating SUPERDONGLE using security server ...
Completed in 3.344 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-411_355717028739407_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
super dangle auth
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
write full pm
Writing PM from Node ...
Section: 1
 - Key: 0, size 12 bytes written.
 - Key: 2, size 70 bytes written.
 - Key: 3, size 70 bytes written.
 - Key: 4, size 70 bytes written.
 - Key: 6, size 276 bytes written.
 - Key: 7, size 276 bytes written.
 - Key: 8, size 276 bytes written.
 - Key: 10, size 384 bytes written.
 - Key: 11, size 384 bytes written.
 - Key: 12, size 384 bytes written.
 - Key: 14, size 384 bytes written.
 - Key: 15, size 384 bytes written.
 - Key: 16, size 384 bytes written.
 - Key: 17, size 32 bytes written.
 - Key: 19, size 16 bytes written.
Section: 2
 - Key: 0, size 440 bytes written.
Section: 4
 - Key: 1, size 800 bytes written.
 - Key: 3, size 10 bytes written.
 - Key: 4, size 8 bytes written.
 - Key: 5, size 8 bytes written.
 - Key: 6, size 8 bytes written.
 - Key: 9, size 5 bytes written.
 - Key: 18, size 80 bytes written.
 - Key: 19, size 4 bytes written.
 - Key: 28, size 2 bytes written.
Section: 8
 - Key: 0, size 2 bytes written.
 - Key: 1, size 16 bytes written.
 - Key: 2, size 16 bytes written.
 - Key: 3, size 128 bytes written.
 - Key: 4, size 128 bytes written.
 - Key: 7, size 4 bytes written.
 - Key: 8, size 8 bytes written.
 - Key: 9, size 8 bytes written.
 - Key: 10, size 24 bytes written.
Section: 11
 - Key: 0, size 4 bytes written.
 - Key: 1, size 4 bytes written.
 - Key: 2, size 4 bytes written.
 - Key: 3, size 4 bytes written.
 - Key: 4, size 1 bytes written.
 - Key: 5, size 6 bytes written.
 - Key: 6, size 2 bytes written.
 - Key: 7, size 1 bytes written.
 - Key: 8, size 1 bytes written.
 - Key: 9, size 1 bytes written.
 - Key: 10, size 1 bytes written.
 - Key: 11, size 1 bytes written.
 - Key: 12, size 1 bytes written.
 - Key: 13, size 1 bytes written.
 - Key: 14, size 2 bytes written.
 - Key: 15, size 2 bytes written.
 - Key: 16, size 2 bytes written.
 - Key: 17, size 2 bytes written.
 - Key: 18, size 16 bytes written.
 - Key: 19, size 32 bytes written.
 - Key: 20, size 32 bytes written.
 - Key: 21, size 2 bytes written.
 - Key: 22, size 2 bytes written.
 - Key: 23, size 2 bytes written.
 - Key: 24, size 2 bytes written.
 - Key: 25, size 2 bytes written.
 - Key: 26, size 2 bytes written.
 - Key: 27, size 2 bytes written.
 - Key: 29, size 2 bytes written.
 - Key: 30, size 2 bytes written.
 - Key: 31, size 2 bytes written.
 - Key: 32, size 2 bytes written.
 - Key: 33, size 2 bytes written.
 - Key: 34, size 2 bytes written.
 - Key: 35, size 2 bytes written.
 - Key: 36, size 2 bytes written.
 - Key: 37, size 2 bytes written.
 - Key: 38, size 2 bytes written.
 - Key: 39, size 2 bytes written.
 - Key: 40, size 2 bytes written.
 - Key: 41, size 2 bytes written.
 - Key: 42, size 2 bytes written.
 - Key: 43, size 2 bytes written.
 - Key: 44, size 2 bytes written.
 - Key: 45, size 2 bytes written.
 - Key: 46, size 2 bytes written.
 - Key: 47, size 2 bytes written.
 - Key: 48, size 2 bytes written.
 - Key: 49, size 2 bytes written.
 - Key: 50, size 2 bytes written.
 - Key: 51, size 2 bytes written.
 - Key: 52, size 2 bytes written.
 - Key: 53, size 2 bytes written.
 - Key: 54, size 2 bytes written.
 - Key: 55, size 2 bytes written.
 - Key: 56, size 2 bytes written.
 - Key: 57, size 2 bytes written.
 - Key: 58, size 2 bytes written.
 - Key: 59, size 2 bytes written.
 - Key: 60, size 2 bytes written.
 - Key: 61, size 2 bytes written.
 - Key: 62, size 2 bytes written.
 - Key: 63, size 2 bytes written.
 - Key: 64, size 2 bytes written.
 - Key: 65, size 2 bytes written.
 - Key: 66, size 4 bytes written.
 - Key: 67, size 1 bytes written.
 - Key: 68, size 4 bytes written.
 - Key: 69, size 4 bytes written.
 - Key: 70, size 4 bytes written.
 - Key: 71, size 4 bytes written.
 - Key: 72, size 16 bytes written.
 - Key: 73, size 4 bytes written.
 - Key: 74, size 2 bytes written.
 - Key: 75, size 13 bytes written.
Section: 12
 - Key: 0, size 102 bytes written.
Section: 13
 - Key: 0, size 1 bytes written.
 - Key: 1, size 2 bytes written.
 - Key: 2, size 1 bytes written.
 - Key: 3, size 2 bytes written.
 - Key: 5, size 1 bytes written.
 - Key: 6, size 1 bytes written.
 - Key: 8, size 2 bytes written.
 - Key: 11, size 48 bytes written.
 - Key: 12, size 4 bytes written.
 - Key: 14, size 1 bytes written.
 - Key: 15, size 886 bytes written.
 - Key: 17, size 1 bytes written.
 - Key: 18, size 1 bytes written.
 - Key: 19, size 8 bytes written.
 - Key: 20, size 1 bytes written.
 - Key: 21, size 1 bytes written.
 - Key: 22, size 1 bytes written.
 - Key: 23, size 1 bytes written.
 - Key: 24, size 1 bytes written.
 - Key: 26, size 1 bytes written.
 - Key: 27, size 1 bytes written.
 - Key: 28, size 1 bytes written.
 - Key: 29, size 1 bytes written.
 - Key: 30, size 1 bytes written.
 - Key: 31, size 1 bytes written.
 - Key: 32, size 1 bytes written.
 - Key: 33, size 1 bytes written.
 - Key: 34, size 1 bytes written.
 - Key: 35, size 1 bytes written.
 - Key: 36, size 1 bytes written.
 - Key: 37, size 4 bytes written.
 - Key: 38, size 1 bytes written.
 - Key: 39, size 1 bytes written.
 - Key: 40, size 1 bytes written.
 - Key: 41, size 1 bytes written.
 - Key: 42, size 4 bytes written.
 - Key: 43, size 4 bytes written.
 - Key: 44, size 1 bytes written.
 - Key: 45, size 4 bytes written.
 - Key: 46, size 4 bytes written.
 - Key: 47, size 1 bytes written.
 - Key: 48, size 4 bytes written.
 - Key: 49, size 1 bytes written.
 - Key: 50, size 1 bytes written.
 - Key: 51, size 1 bytes written.
 - Key: 53, size 4 bytes written.
 - Key: 54, size 4 bytes written.
 - Key: 55, size 1 bytes written.
 - Key: 56, size 1 bytes written.
 - Key: 57, size 1 bytes written.
 - Key: 59, size 1 bytes written.
 - Key: 60, size 4 bytes written.
 - Key: 61, size 4 bytes written.
 - Key: 62, size 1 bytes written.
 - Key: 63, size 4 bytes written.
 - Key: 64, size 4 bytes written.
 - Key: 65, size 1 bytes written.
 - Key: 67, size 4 bytes written.
 - Key: 68, size 1 bytes written.
 - Key: 69, size 1 bytes written.
 - Key: 70, size 1 bytes written.
 - Key: 72, size 4 bytes written.
 - Key: 73, size 1 bytes written.
 - Key: 74, size 4 bytes written.
 - Key: 75, size 2 bytes written.
 - Key: 76, size 2 bytes written.
 - Key: 77, size 2 bytes written.
 - Key: 78, size 1 bytes written.
 - Key: 79, size 1 bytes written.
 - Key: 80, size 1 bytes written.
 - Key: 81, size 1 bytes written.
 - Key: 82, size 1 bytes written.
 - Key: 83, size 2 bytes written.
 - Key: 84, size 1 bytes written.
 - Key: 85, size 4 bytes written.
 - Key: 86, size 4 bytes written.
 - Key: 87, size 2 bytes written.
 - Key: 88, size 1 bytes written.
 - Key: 89, size 4 bytes written.
 - Key: 90, size 4 bytes written.
 - Key: 91, size 2 bytes written.
 - Key: 92, size 1 bytes written.
 - Key: 93, size 4 bytes written.
 - Key: 94, size 4 bytes written.
 - Key: 95, size 2 bytes written.
 - Key: 96, size 1 bytes written.
 - Key: 97, size 4 bytes written.
 - Key: 98, size 4 bytes written.
 - Key: 99, size 2 bytes written.
 - Key: 100, size 4 bytes written.
 - Key: 101, size 2 bytes written.
 - Key: 102, size 1 bytes written.
 - Key: 103, size 4 bytes written.
 - Key: 104, size 4 bytes written.
 - Key: 105, size 4 bytes written.
 - Key: 106, size 4 bytes written.
 - Key: 107, size 4 bytes written.
 - Key: 108, size 2 bytes written.
 - Key: 109, size 4 bytes written.
 - Key: 110, size 4 bytes written.
 - Key: 111, size 4 bytes written.
 - Key: 112, size 2 bytes written.
 - Key: 113, size 4 bytes written.
 - Key: 114, size 4 bytes written.
 - Key: 115, size 1 bytes written.
 - Key: 116, size 1 bytes written.
 - Key: 117, size 1 bytes written.
 - Key: 118, size 4 bytes written.
 - Key: 119, size 4 bytes written.
 - Key: 120, size 1 bytes written.
 - Key: 121, size 1 bytes written.
 - Key: 122, size 1 bytes written.
 - Key: 123, size 8 bytes written.
 - Key: 124, size 1 bytes written.
 - Key: 125, size 1 bytes written.
 - Key: 126, size 1 bytes written.
 - Key: 127, size 1 bytes written.
 - Key: 128, size 1 bytes written.
 - Key: 129, size 4 bytes written.
 - Key: 130, size 4 bytes written.
 - Key: 131, size 1 bytes written.
 - Key: 132, size 1 bytes written.
 - Key: 133, size 2 bytes written.
 - Key: 134, size 1 bytes written.
 - Key: 135, size 2 bytes written.
 - Key: 136, size 1 bytes written.
 - Key: 137, size 1 bytes written.
 - Key: 138, size 4 bytes written.
 - Key: 139, size 4 bytes written.
 - Key: 140, size 1 bytes written.
 - Key: 141, size 1 bytes written.
 - Key: 142, size 1 bytes written.
 - Key: 143, size 1 bytes written.
 - Key: 144, size 4 bytes written.
 - Key: 145, size 8 bytes written.
 - Key: 146, size 4 bytes written.
 - Key: 147, size 4 bytes written.
 - Key: 148, size 1 bytes written.
 - Key: 149, size 1 bytes written.
 - Key: 150, size 1 bytes written.
 - Key: 151, size 1 bytes written.
 - Key: 152, size 1 bytes written.
 - Key: 153, size 1 bytes written.
 - Key: 154, size 1 bytes written.
 - Key: 155, size 1 bytes written.
 - Key: 156, size 1 bytes written.
 - Key: 157, size 1 bytes written.
 - Key: 158, size 1 bytes written.
 - Key: 159, size 2 bytes written.
 - Key: 160, size 2 bytes written.
 - Key: 161, size 1 bytes written.
 - Key: 162, size 1 bytes written.
 - Key: 163, size 1 bytes written.
 - Key: 164, size 1 bytes written.
 - Key: 165, size 1 bytes written.
 - Key: 166, size 1 bytes written.
 - Key: 167, size 8 bytes written.
 - Key: 168, size 4 bytes written.
 - Key: 169, size 1 bytes written.
 - Key: 170, size 1 bytes written.
 - Key: 171, size 1 bytes written.
 - Key: 172, size 1 bytes written.
 - Key: 173, size 1 bytes written.
 - Key: 174, size 1 bytes written.
 - Key: 175, size 1 bytes written.
 - Key: 176, size 1 bytes written.
 - Key: 177, size 4 bytes written.
 - Key: 178, size 2 bytes written.
 - Key: 179, size 1 bytes written.
 - Key: 180, size 1 bytes written.
 - Key: 181, size 1 bytes written.
 - Key: 182, size 1 bytes written.
 - Key: 183, size 1 bytes written.
 - Key: 184, size 1 bytes written.
 - Key: 185, size 1 bytes written.
 - Key: 186, size 1 bytes written.
 - Key: 187, size 1 bytes written.
 - Key: 188, size 1 bytes written.
 - Key: 189, size 1 bytes written.
 - Key: 190, size 4 bytes written.
 - Key: 191, size 2 bytes written.
 - Key: 192, size 1 bytes written.
 - Key: 193, size 4 bytes written.
 - Key: 194, size 1 bytes written.
 - Key: 195, size 1 bytes written.
 - Key: 196, size 10 bytes written.
Section: 31
 - Key: 4, size 18 bytes written.
Section: 42
 - Key: 1, size 12 bytes written.
 - Key: 2, size 36 bytes written.
 - Key: 3, size 36 bytes written.
 - Key: 4, size 36 bytes written.
 - Key: 5, size 36 bytes written.
 - Key: 6, size 36 bytes written.
 - Key: 7, size 40 bytes written.
 - Key: 8, size 40 bytes written.
 - Key: 9, size 40 bytes written.
 - Key: 10, size 40 bytes written.
 - Key: 11, size 40 bytes written.
 - Key: 12, size 40 bytes written.
 - Key: 13, size 40 bytes written.
 - Key: 14, size 40 bytes written.
Section: 44
Section: 50
Section: 54
Section: 66
 - Key: 0, size 524 bytes written.
 - Key: 1, size 240 bytes written.
 - Key: 2, size 240 bytes written.
 - Key: 3, size 1 bytes written.
 - Key: 5, size 240 bytes written.
 - Key: 6, size 4 bytes written.
 - Key: 8, size 4 bytes written.
 - Key: 9, size 4 bytes written.
 - Key: 10, size 240 bytes written.
 - Key: 11, size 240 bytes written.
 - Key: 16, size 4 bytes written.
 - Key: 18, size 4 bytes written.
 - Key: 20, size 4 bytes written.
 - Key: 22, size 4 bytes written.
 - Key: 24, size 4 bytes written.
 - Key: 26, size 4 bytes written.
 - Key: 28, size 4 bytes written.
 - Key: 30, size 4 bytes written.
 - Key: 32, size 4 bytes written.
 - Key: 34, size 4 bytes written.
 - Key: 57, size 8 bytes written.
 - Key: 58, size 8 bytes written.
 - Key: 59, size 8 bytes written.
 - Key: 60, size 8 bytes written.
 - Key: 61, size 8 bytes written.
 - Key: 75, size 8 bytes written.
 - Key: 76, size 8 bytes written.
 - Key: 77, size 24016 bytes written.
 - Key: 78, size 6144 bytes written.
 - Key: 79, size 300 bytes written.
 - Key: 80, size 60 bytes written.
 - Key: 84 skipped, frame length too long
 - Key: 91, size 3 bytes written.
 - Key: 92, size 3 bytes written.
 - Key: 93, size 3 bytes written.
 - Key: 94, size 3 bytes written.
 - Key: 95, size 3 bytes written.
 - Key: 96, size 3 bytes written.
 - Key: 108, size 4 bytes written.
 - Key: 111, size 6 bytes written.
 - Key: 122, size 120 bytes written.
 - Key: 125, size 30 bytes written.
 - Key: 130, size 8 bytes written.
 - Key: 133, size 7 bytes written.
Section: 88
 - Key: 0, size 36 bytes written.
Section: 96
 - Key: 1, size 20 bytes written.
Section: 107
 - Key: 0, size 21 bytes written.
 - Key: 1, size 89 bytes written.
 - Key: 2, size 69 bytes written.
 - Key: 25, size 132 bytes written.
 - Key: 26, size 12 bytes written.
Section: 116
 - Key: 15, size 40 bytes written.
 - Key: 16, size 40 bytes written.
Section: 153
 - Key: 0, size 68 bytes written.
 - Key: 1, size 68 bytes written.
 - Key: 2, size 68 bytes written.
 - Key: 3, size 68 bytes written.
 - Key: 4, size 68 bytes written.
 - Key: 5, size 68 bytes written.
Section: 193
 - Key: 2, size 8 bytes written.
 - Key: 3, size 32 bytes written.
 - Key: 4, size 32 bytes written.
 - Key: 9, size 64 bytes written.
Section: 217
 - Key: 0, size 32 bytes written.
Section: 218
Section: 232
 - Key: 0, size 20 bytes written.
Section: 238
 - Key: 1, size 1 bytes written.
Section: 250
 - Key: 1, size 2320 bytes written.
 - Key: 2, size 128 bytes written.
 - Key: 3, size 812 bytes written.
 - Key: 4, size 40 bytes written.
Section: 301
Section: 309
 - Key: 2, size 12 bytes written.
 - Key: 4, size 12 bytes written.
 - Key: 5, size 12 bytes written.
 - Key: 7, size 12 bytes written.
 - Key: 8, size 12 bytes written.
 - Key: 17, size 12 bytes written.
 - Key: 22, size 12 bytes written.
Section: 320
 - Key: 0, size 148 bytes written.
 - Key: 1, size 148 bytes written.
 - Key: 2, size 148 bytes written.
 - Key: 3, size 148 bytes written.
 - Key: 4, size 148 bytes written.
 - Key: 5, size 148 bytes written.
 - Key: 6, size 148 bytes written.
 - Key: 7, size 148 bytes written.
 - Key: 8, size 148 bytes written.
 - Key: 9, size 148 bytes written.
 - Key: 10, size 148 bytes written.
 - Key: 11, size 148 bytes written.
 - Key: 12, size 148 bytes written.
 - Key: 13, size 148 bytes written.
 - Key: 14, size 148 bytes written.
 - Key: 15, size 148 bytes written.
 - Key: 16, size 148 bytes written.
 - Key: 17, size 148 bytes written.
 - Key: 18, size 148 bytes written.
 - Key: 19, size 148 bytes written.
 - Key: 20, size 148 bytes written.
 - Key: 21, size 148 bytes written.
 - Key: 22, size 148 bytes written.
 - Key: 23, size 148 bytes written.
 - Key: 24, size 148 bytes written.
 - Key: 25, size 148 bytes written.
 - Key: 26, size 148 bytes written.
 - Key: 27, size 148 bytes written.
 - Key: 28, size 148 bytes written.
 - Key: 29, size 148 bytes written.
 - Key: 30, size 148 bytes written.
 - Key: 31, size 148 bytes written.
 - Key: 32, size 148 bytes written.
 - Key: 33, size 148 bytes written.
 - Key: 34, size 148 bytes written.
 - Key: 35, size 148 bytes written.
 - Key: 36, size 148 bytes written.
 - Key: 37, size 148 bytes written.
 - Key: 38, size 148 bytes written.
Section: 322
Section: 334
Section: 339
 - Key: 0, size 511 bytes written.
 - Key: 1, size 511 bytes written.
Section: 341
 - Key: 4, size 4418 bytes written.
Section: 345
Section: 354
 - Key: 0, size 3 bytes written.
Section: 355
 - Key: 1, size 2028 bytes written.
Section: 356
Section: 362
 - Key: 1, size 144 bytes written.
Section: 364
Section: 365
Completed in 34.719 s
then reset all final scan
Product Code: 0563611
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
thanks mx-key team
do not forget say
The Following 8 Users Say Thank You to live14 For This Useful Post:
Old 06-17-2010, 20:02   #2 (permalink)
romeoluv56's Avatar
Member: 1170910
Thanks Meter: 76
Old Story, but nice info share
The Following User Says Thank You to romeoluv56 For This Useful Post:
Old 06-17-2010, 20:45   #3 (permalink)
Member: 599384
Thanks Meter: 21
thanks for your efforts but all people know this steps
The Following User Says Thank You to remo_m_m For This Useful Post:
Old 03-02-2011, 10:33   #4 (permalink)
ozanah's Avatar
Member: 752357
Sonork: miker cellular centre
Thanks Meter: 22
thx for sharing bro u help us
The Following User Says Thank You to ozanah For This Useful Post:
Old 03-02-2011, 10:58   #5 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
nice share for people who don't know it yet...
repost for people who have already known it....
but it is a good effort though.
thanks
The Following User Says Thank You to specta For This Useful Post:
Old 03-02-2011, 11:22   #6 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 552
Anybody tested this ???
Please post the result....
The Following User Says Thank You to ABDUL RAJA For This Useful Post:
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.23281 seconds with 9 queries
