05-28-2010, 18:13 | #1 (permalink) |
Insane Poster Join Date: Feb 2009
Member: 974162 Status: Offline Sonork: QuanVV Thanks Meter: 43 | N72 config key: 0000000000000000 log info here Code: Powering the phone... Reading... MCU SW version: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia. HW version: 5001 PCI version: RFIC version: 150a160f DSP version: rolf_espresso_05wk07v29p1 Retu version: 32 Tahvo version: 53 Production serial number: CIJ206164 Product code: 0531541 Module code: Basic production code: 0530940 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356295019081757 IMEI spare to net: 3A 65 92 05 91 80 71 05 IMEI SV to net: 33 65 92 05 91 80 71 05 F9 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Block 3: Lock 1: OPEN Block 4: Lock 1: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0531541 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50741401.C0 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50741401.V12 CNT Flash file: NONE APE Variant file: NONE Languages in ppm: English,Trad Chinise,Indian Done! |
05-28-2010, 18:30 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
The Following User Says Thank You to curvenger For This Useful Post: |
05-28-2010, 18:35 | #3 (permalink) | |
Member: 974162 Status: Offline Sonork: QuanVV Thanks Meter: 43 | Quote:
Code: SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed SX4 No SX4 Card found. Authenticating using security server ... Connecting to server[mxkey.selfip.biz] ...MXKEY-SX4 ver 2.5(ID), hello 118.68.27.135 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request | |
05-28-2010, 18:45 | #4 (permalink) | |
No Life Poster Join Date: Sep 2007
Member: 582669 Status: Offline Sonork: 100.1592908 Thanks Meter: 69 | Quote:
The Following User Says Thank You to arvinddald For This Useful Post: |
05-28-2010, 19:09 | #5 (permalink) | |
Code: Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 1 (4 bytes) Warning: failed to write 1 - 2 (86 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (86 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (86 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (86 bytes) Warning: failed to write 1 - 18 (86 bytes) Warning: failed to write 1 - 20 (86 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (16 bytes) Warning: failed to write 1 - 29 (6 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Completed in 3.328 s Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request | |
05-28-2010, 19:16 | #6 (permalink) | |
Member: 974162 Status: Offline Sonork: QuanVV Thanks Meter: 43 | and now...............phone star up failed Quote:
05-28-2010, 19:31 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | contact yahoo mesenger to me................... [email protected] |
FAID=000000000000000 | Ebi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-23-2002 11:34 |
82x0 Contact Service - IMEI 000000000000000 | Phantom_gst | Nokia Hardware & Hardware Repair | 0 | 10-30-2001 23:10 |
NOKIA 3390 CONFIG FILE ENTRY NEEDED URGENT | JBABOUN | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-17-2001 20:03 |
NOKIA 3390 CONFIG FILE ENTRY NEEDED URGENT | JBABOUN | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-17-2001 20:02 |
NOKIA 3390 CONFIG FILE ENTRY NEEDED URGENT | JBABOUN | Old Ericsson Phones & Sony Phones | 0 | 04-17-2001 19:58 |
