Old 11-12-2010, 08:02   #1 (permalink)
Member: 1187394
Thanks Meter: 14
Unhappy n72 Fill and remain parked in logo nokia (answered)
Version from phone: 5.0819.4.0.1
Version from file: 50819401.V08
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35938000364714_BA CK.rpl).
Processing MCU file: RM180_50819401.V08
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 10.77 MB
Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
Supported Ids: 17100700, 17100701, 17100702, 17100703
APE Data :
SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
ASIC MODE ID: 00
PUBLIC ID: 8FDBDA98E199FC25558C152AF7423947D535083D
ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM0 ID: 00000232
EM1 ID: 00000341
PUBLIC ID: 19600106D88F4951DDE5A79DBC5D898810E1C76C
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE
ALG [35]: OMAP1610 GBBM-1.8.1 ALG
ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000
Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908
APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
Partitioning ...OK
Erase size: 35.94 MB
APE NAND area [01AE0000-02AFFFFF] erased in 1.734 s
APE NAND area [02B00000-03ECFFFF] erased in 2.157 s
Flash programming ...
Programming completed in 1 min 43.734 s
Processing PPM file: RM180_50819401.C0
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 28.69 MB
Supported Ids: 0003192101012200, 000C192101012200
Supported Ids: 17100701, 17100702
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000341
ASIC MODE ID: 00
Partitioning ...OK
Erase size: 68.92 MB
CMT NOR area [00000000-0052B6C1] erased in 41.500 s
CMT NOR area [006A0000-006BFFFF] erased in 1.094 s
CMT NOR area [006DF000-006EFFFF] erased in 1.078 s
CMT NOR area [00700000-007EFFFF] erased in 7.547 s
APE NAND area [00000000-0000FFFF] erased in 0.156 s
APE NAND area [00010000-0001FFFF] erased in 0.172 s
APE NAND area [00020000-000203FF] erased in 0.156 s
APE NAND area [00050000-03ECFFFF] erased in 6.593 s
CMT PAPUBKEYS: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D (Rap certificate3) written.
APE PAPUBKEYS: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D (APE certificate3) written.
Programming completed in 3 min 8.281 s
Total time for flashing process(boot+erase+write) was 6 min 9.562 s
Flashing completed in 6 min 12.359 s
After Flash Processing ...
Reseting Factory Values OK.
Phone Type: RM-180 (Nokia N72)
SW Version: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia.
Imei plain: 35938000364714-9
Product Code: 0529147
Language Pack:
- not available.
SIMLOCK seems to be valid
Imei net: 359380003647149
Version: SIMLOCK SERVER VERSION 58
Provider: Virgin, Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2343000000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN, DATA=23430F
BLOCK 2: 1=OPEN, DATA=23430F
i flach it but the problem not change on in logo nokia
The Following User Says Thank You to barika05 For This Useful Post:
Old 11-12-2010, 08:06   #2 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Sometime Problem become in hardware.
so check in hardware also.
Br.
Old 11-12-2010, 08:16   #3 (permalink)
Member: 1187394
Thanks Meter: 14
can you give me solution help me plz and great thx
Old 11-12-2010, 09:10   #4 (permalink)
Member: 1187394
Thanks Meter: 14
?????????? help me بارك الله فيك
Old 11-12-2010, 12:11   #5 (permalink)
sharpgsm's Avatar
Member: 313652
Sonork: 100.1625717
Thanks Meter: 99
It's surely hardware problem it happens due to dry flash n retu also
Old 11-12-2010, 17:24   #6 (permalink)
Member: 1187394
Thanks Meter: 14
what i can do?? my thx is advance
Old 11-12-2010, 22:05   #7 (permalink)
realtech's Avatar
Member: 1003310
Thanks Meter: 28
Problem in power TAHVO ic try to take all rpl backup after that try reheating or reballing
Old 11-12-2010, 23:19   #8 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
execute self test for further analysis.
Old 11-13-2010, 15:19   #9 (permalink)
Member: 1187394
Thanks Meter: 14
Phone Type: RM-180
SW version: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia.
ID Test name Startup Result
20 BACKUP_BATT N !NOT EXECUTED(03)
101 BTEMP N !NOT EXECUTED(03)
107 BT_SLEEP_CLK N !NOT EXECUTED(03)
71 BT_WAKEUP N !NOT EXECUTED(03)
22 CAMERA_IF N !no signal
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
86 CDSP_RF_BB_IF N !NOT EXECUTED(03)
83 CDSP_RF_SUPPLY N !NOT EXECUTED(03)
81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03)
79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
74 CDSP_TXC_DATA N !NOT EXECUTED(03)
85 CDSP_TX_IQ N !no signal
80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
58 CMT_APE_WAKEUP N !NOT EXECUTED(03)
2 CURRENT_CONS N passed
3 EAR_DATA_LOOP Y passed
96 HOOKINT N !NOT EXECUTED(03)
7 KEYBOARD_STUCK N !NOT EXECUTED(03)
44 LPRF_AUDIO_LINES N passed
21 LPRF_IF N passed
59 MAIN_LCD_IF N !NOT EXECUTED(03)
90 PWR_KEY N !NOT EXECUTED(03)
42 RADIO N !no signal
93 SECURITY N !NOT EXECUTED(03)
12 SIM_CLK_LOOP Y PASSED(00)
13 SIM_IO_CTRL_LOOP Y passed
33 SIM_LOCK N passed
56 SLEEPCLK_FREQ Y passed
88 TAHVOINT Y PASSED(00)
46 UEM_CBUS_IF Y passed
49 VIBRA N !NOT EXECUTED(03)
Old 11-13-2010, 15:52   #10 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
seems that hw side all ok.
what is the initial condition?
if after normal firmware update phone stay the same on stuck , blink, blank, etc.
it's needed extra ordinary way.
- try to apply rap3nand erase from quick fix.
- if no help, do full erase - reflash - restore procedure. do with caution, pay attention on security backup (rpl, pm, etc)
Old 11-13-2010, 18:20   #11 (permalink)
Member: 1187394
Thanks Meter: 14
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000341
ASIC MODE ID: 00
Original Imei: Empty
Original Product code: Empty
NPC_DATA invalid !
Imei plain: 12345610654321-?
Language Pack:
- not available.
Imei plain is invalid !!!
Imei net: 12345610654321?
Counter: 0/3, 0/10
when erase and i flach it but i have backup.thanks bro
Old 11-13-2010, 18:24   #12 (permalink)
Member: 1187394
Thanks Meter: 14
now when repair simlock
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000341
ASIC MODE ID: 00
NPC_DATA invalid !
Language Pack:
- not available.
Counter: 0/3, 0/10
Old 11-13-2010, 18:35   #13 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000341
ASIC MODE ID: 00
NPC_DATA invalid !
Language Pack:
- not available.
Counter: 0/3, 0/10
Have u backup Rpl is yes then u need to restore rpl backup after bakcup rpl ur set not power on then u need fbus cable of this model becoz i also faced this problem from mx key after usb flash set not power on use fbus cable and flash again 1000% set ok if not then flash with ufs with fbus cable tested
Old 11-13-2010, 19:32   #14 (permalink)
Member: 1187394
Thanks Meter: 14
Version from file: 50819401.V15
Processing MCU file: RM180_50819401.V15
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 8.15 MB
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000341
ASIC MODE ID: 00
Partitioning ...OK
APE NAND area [02B00000-03ECFFFF] erased in 2.172 s
Programming completed in 1 min 18.562 s
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000341
ASIC MODE ID: 00
Partitioning ...OK
CMT NOR area [00000000-0052B6C1] erased in 41.203 s
CMT NOR area [006A0000-006BFFFF] erased in 1.062 s
CMT NOR area [00700000-007EFFFF] erased in 7.438 s
APE NAND area [00010000-0001FFFF] erased in 0.157 s
APE NAND area [00020000-000203FF] erased in 0.172 s
Programming completed in 3 min 7.812 s
Total time for flashing process(boot+erase+write) was 5 min 43.641 s
Flashing completed in 5 min 46.250 s
Language Pack:
- not available.
Counter: 0/3, 0/10
Fill and remain parked in logo nokia the problem is fix ??????
Old 11-14-2010, 08:38   #15 (permalink)
Member: 1187394
Thanks Meter: 14
can you help me Riz000 and greazt thanks bro
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.32540 seconds with 9 queries
