04-22-2010, 16:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | n72 flashing error with new ver.1.8 fix... [HARDWARE PROBLEM - SOLVED] senior member should look after this log... scan info Phone Type: RM-180 (Nokia N72) SW Version: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia. Imei plain: 354533********** Product Code: 0531541 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35453********** Version: SIMLOCK SERVER VERSION 58 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF flashing log Version from phone: 05wk07v47 Version from file: 50819401.C0 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8069(22-04-2010), 1.0.0.12811(22-04-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2290000632CC585142C4DCC70F3C88E0EC3B9F41 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Reading RAP NPC (0x168 bytes). Reading RAP VARIANT (0x4ED bytes). Reading RAP CCC (0x0 bytes). Reading RAP HWC (0x0 bytes). Flash Imei: 3545********** NPC_DATA saved OK VARIANT_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35453301649137_BA CK.rpl" Processing file: RM180_50819401.C0 as MCU [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 28.69 MB Supported RAP Ids: 0003192101012200, 000C192101012200 Supported APE Ids: 17100701, 17100702 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2290000632CC585142C4DCC70F3C88E0EC3B9F41 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Partitioning ...OK Erase size: 68.92 MB CMT NOR area [00000000-0052B6C1] erased in 40.547 s CMT NOR area [006A0000-006BFFFF] erased in 1.093 s CMT NOR area [006DF000-006EFFFF] erased in 1.047 s CMT NOR area [00700000-007EFFFF] erased in 7.032 s APE NAND area [00000000-0000FFFF] erased in 0.156 s warning : erase sector address out of chip bound. APE NAND area [00010000-0001FFFF] erased in 0.172 s warning : erase sector address out of chip bound. APE NAND area [00020000-000203FF] erased in 0.187 s warning : erase sector address out of chip bound. APE NAND area [00050000-03ECFFFF] erased in 0.157 s warning : erase sector address out of chip bound. Flash programming ... CMT PAPUBKEYS: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D (Rap certificate3) written. Error chk C7012D0100D0000010000000F1 Error while programming [01] at 0x00000000, Result: 0010 Flashing terminated with error(s) in 1 min 56.438 s RX Buffer: C7012D0100D0000010000000F172 |
04-22-2010, 16:37 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | always or temporary ? how if retry your JOB after recheck cable connector br, |
The Following User Says Thank You to Andra For This Useful Post: |
04-23-2010, 13:51 | #5 (permalink) |
Member: 982335 Status: Offline Thanks Meter: 202 | |
04-23-2010, 14:19 | #6 (permalink) |
Member: 982335 Status: Offline Thanks Meter: 202 | sir this problrm can be for ufs interface? as my jaf box is dead i can't test . i think we need mx key interface as soon as possible. i m loosing money as my jaf is dead & mx key giving error while flashing. sir please do something for us. |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
