08-30-2009, 14:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: IN MY PC
Member: 745721 Status: Offline Sonork: 100.1605292 Thanks Meter: 2,390 | n72 phone start-up faild contact the retaler plz help MCU SW version: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia. HW version: 5000 RFIC version: 150a160f DSP version: rolf_espresso_05wk07v29p1 Retu version: 32 Tahvo version: 52 Product Info: Production serial number: CII962742 Product code: 0531541 Module code: 0203723 Basic production code: 0530940 Serial Numbers: IMEI plain: 359726006053232 IMEI spare to net: 3A 95 27 06 60 50 23 03 IMEI SV to net: 33 95 27 06 60 50 23 03 F9 Other Info: Model : Nokia N72 (Imaging Phone) CS type : GSM900/GSM1800/GSM1900 Project Name: Rolf Espresso N72 BSI: 0.4 KOhm Imei: 359726006053232 Version: SIMLOCK SERVER VERSION 58 Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23594F BLOCK 3: 1=OPEN, DATA=23420F BLOCK 4: 1=OPEN, DATA=23594F Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server ...MXKEY-Server v2.4 hello 119.30.34.26 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request i try to write pm with sx4 but this error Last edited by R@jusat; 08-30-2009 at 15:01. |
08-30-2009, 15:03 | #3 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | man look - Connecting to server ...MXKEY-Server v2.4 hello 119.30.34.26 Wrong response to SD verify request Bad phones ack, probably SUPERDONGLE_KEY corrupted - BRO YOUR RPL IS CORRUPTED TRY THIS METHOD BY USING MXKEY GO IMEI AND SECURITY AND UPDATE SPLOCK AND ALL THOSE ITEM STILL NO SOLUTION TRY TO DOWNDRADE YOUR VERSION AND TRY THIS METHOD |
08-30-2009, 18:43 | #12 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | only calculated RPL from nokia server can completly salove ur problem. but Nokia BB5 rpl is temporarly down at this time |
08-30-2009, 22:48 | #13 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | Quote:
u can make rp sl data and make unlock ,but (phone will turn of every 10 minutes) cause phone superdongle corupted | |
The Following User Says Thank You to mohA™ For This Useful Post: |
N72 Phone start-up faild.contact the retailer | pranav_raj2587 | Nokia Base Band 5 ( BB-5 ) | 8 | 07-01-2010 16:18 |
7610 Phone Start-up Faild.contact The Retailer | harisha g h | Nokia Hardware & Hardware Repair | 9 | 03-08-2010 20:37 |
nokia n85 phone start-up faild contact the retailer plz help....... | RABIULSK | Nokia Hardware & Hardware Repair | 5 | 02-02-2010 06:43 |
please help me big problem n72 phone start-up failed contact the retailer........ | swechacnu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 10-07-2009 17:31 |
N85 After ‘unlock Zulea Phone start-up failed.contact the retaler | azouqa | BB5KING | 9 | 05-27-2009 07:43 |
