09-15-2011, 08:48 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | n72 SUPERDONGLE_KEY invalid! SW version: V 05wk07v42.2 13-04-06 RM-180 (c) Nokia. Imei plain: 35972600401960-7 Product code: 0530869 Battery voltage: 4567 mV, current: 0 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed warning: phone version(2.0617.1.0.3) outdated, latest version on server is: 57.21 Imei net: 359726004019607 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F |
09-15-2011, 09:23 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | PM section 1 & 309 write if found Security test fail in Your case you need to repair the SD key > then do SP unlock |
09-15-2011, 09:29 | #5 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | repair simlock Imei net: 359726004019607 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C08541A4 Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Phone type: RM-180 (Nokia N70) SW version: V 05wk07v42.2 13-04-06 RM-180 (c) Nokia. Reading Simlock info ... Imei net: 359726004019607 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F |
09-15-2011, 17:21 | #7 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Makum, Assam, India
Member: 1540165 Status: Offline Sonork: 100.1606502 Thanks Meter: 29 | Only Simlock Updae is not correct solution for this phone. The proper solution is ==== In this case you need to repair the SD key and then do SP unlock use sx4 if needed to write PM [1,309] Do not ignor it Quote:
C28 v61 when i use Swup say: invalid char received | xxxpaga | x1x to x45/x50 | 3 | 10-18-2001 18:36 |
StarTac 85-invalid batery! | gera5 | Motorola Old Legacy (EMMI) | 0 | 10-13-2001 17:38 |
StarTac 85-invalid batery! | gera5 | Motorola Old Legacy (EMMI) | 0 | 09-23-2001 23:37 |
Invalid sim on Nokia 6210 | dario | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-23-2001 02:19 |
help ! invalid battery | cyber6 | Motorola Old Legacy (EMMI) | 1 | 11-28-1999 06:11 |
