05-14-2010, 00:11 | #5 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | All server are up and running well. probably you are using an old version of mxkey software. Please read news about last update: http://forum.gsmhosting.com/vbb/5793184-post85.html - Due to keep the server stability, older server will be removed and all older releases are obsolete. BR, Manole |
The Following 3 Users Say Thank You to MANOLE For This Useful Post: |
05-14-2010, 05:39 | #7 (permalink) |
No Life Poster Join Date: Jan 2008 Location: NIGERIA
Member: 676315 Status: Offline Thanks Meter: 120 | Please help me my repair sd,simlock repair,sign application is working but sd auth and pmm is not working for past 9 days,is my dongle or ip or what please help me. |
The Following User Says Thank You to wisdom001 For This Useful Post: |
05-14-2010, 07:06 | #8 (permalink) |
No Life Poster Join Date: May 2008 Location: amman
Member: 764174 Status: Offline Thanks Meter: 259 | remove any old mx old software and install the latest and try many times with ppm auth or super pm auth sometimes srever busy if not solve use recover cert or edit rpl manual and try again |
The Following User Says Thank You to ahmad yousif For This Useful Post: |
05-14-2010, 14:05 | #9 (permalink) |
No Life Poster Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | after update sd ihave wright pm but see this Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 06.65 01-04-09 RM-495 (c) Nokia Using cached productData[0F50021836027D5667F882089014A071BA4F68C4] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
05-14-2010, 20:17 | #10 (permalink) | |
Member: 764174 Status: Offline Thanks Meter: 259 | Quote:
then retry to reconnect to server again & again tell phone respond to super sd auth & write the 2 fields of pm post result | |
05-14-2010, 22:18 | #11 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | Follow manole steps You need to write CORRECT PM or as alternative use 'Load RF/BB from Server' so sw will request PM from server and write to the phone. |
The Following User Says Thank You to alasmmar For This Useful Post: |
