05-04-2010, 19:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Where the cash @... Age: 38
Member: 450871 Status: Offline Sonork: 100.1592197 Thanks Meter: 121 | N73 contact retailer not solved Phone Type: RM-132 (Nokia N73) SW Version: V 05wk47v53 26-10-07 RM-132 (c) Nokia. Imei plain: 35XXXXXXX Product Code: 0545033 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35XXXXXXXX Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BR, ERIC |
05-04-2010, 21:37 | #3 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, there is no difference process on old and new mxkey version. if you done before, it should be done now, too. check more by using certificate validation tool. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
05-07-2010, 08:33 | #7 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | Quote:
1_ Write pm filed 1 and 309 after PM Auth or Super SD Auth. 2_If failed Do Recover Crt from IMEI& Security Tab. 3_ If still failed once downgrade the phone and than try above steps 4_ If Still failed upgrade it back and do step 1 if failed step 2 Mate I have solved many strict Contact Retailer Cases by above method I hope it will help you too. WBR | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
