Old 02-10-2010, 06:24   #1 (permalink)
Member: 1228159
e62.repair sd data & security data ok.but still contect retaile
Phone Type: RM-88 (Nokia E62)
SW Version:
V 3.06.33.09.13 17-08-07 RM-88 (c) Nokia.
Imei plain:
35974300050986-1
Product Code:
0538175
ApeCoreSw:
3.0633.31.19 17-08-07 RM-88 (c)Nokia
ApeVariant:
3.0633.31.19_v08 17-08-07 RM-88 (c)Nokia
ContentPack:
V1.0 Default RM-88
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
"RM-88" folder created.
Imei net:
359743000509861
Version:
SIMLOCK SERVER VERSION 62
Counter: 0/3, 0/10
CONFIG_DATA:
FFFFFFFFFFFFFFFF
PROFILE_BITS:
FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
i repair sd data & write pm with super sd auth. but still contect retailer.
SW Version: V 3.06.33.09.13 17-08-07 RM-88 (c) Nokia.
Imei plain: 35974300050986-1
Product Code: 0537120
ApeCoreSw: 3.0633.31.19 17-08-07 RM-88 (c)Nokia
ApeVariant: 3.0633.31.19_v08 17-08-07 RM-88 (c)Nokia
ContentPack: V1.0 Default RM-88
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 359743000509861
Version: SIMLOCK SERVER VERSION 62
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
how to repair block 1 : 1=corrupted
BB5 Certivicate Validation
Service > Phone Test > Various > BB5 Certivicate Validation
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 190001176C49005278291EC22A4A0DD3AAF4E67B
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 22FE - 0000 8D21 [Samsung K8S5615ETA,256 Mbits] type: NOR,RAP
FlashID1: 00EC 0030 - 0000 0011 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: ONENAND,RAP
ALG [35]: BB5 ALGORITHM
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 8665D276B9147EE40DF77CF6781A675E57D46867
Reading RAP NPC (0x168 bytes)
Original Product Code: 0551010
Reading RAP VARIANT (0x4EF bytes)
Product Code missmatch !
Reading RAP CCC (0x0 bytes)
Reading RAP HWC (0x0 bytes)
still contect retailer. pls help me.
Old 02-10-2010, 07:08   #2 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
SW Version:
Imei plain:
35974300050986-1
Product Code:
0538175
ApeCoreSw:
ApeVariant:
ContentPack:
V1.0 Default RM-88
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net:
359743000509861
Version:
Counter: 0/3, 0/10
CONFIG_DATA:
FFFFFFFFFFFFFFFF
PROFILE_BITS:
FFFFFFFFFFFFFFFF
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
repair sd n write pm filed 1 n 309 with super sd auth.
Old 02-10-2010, 07:09   #3 (permalink)
Member: 5358
Thanks Meter: 211
open the phone and check the hardware maybe its been unauthorized repaired.
Old 02-10-2010, 09:31   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
1.do SX-4 and write PM without [308] area
in case after Superdongle repair , please use "SUPER SD Auth"
2.do "Recover CERT" , if doesn't work
Begin Certificate Request ...
Connecting to server ...OK, Login ...
ERROR: No certificate found in the database !
check this
Just in case if Recovery via Server doesn't work.......
need more file about CCC,HWC and VARIANT
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 02-10-2010, 12:28   #5 (permalink)
Member: 1228159
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 59.95.210.146
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 02-10-2010, 16:02   #6 (permalink)
Crazy Poster
Member: 170884
Thanks Meter: 3
Smile
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
repair simlock too ........................
SD & simlock is ok but I can't do PM Auth !!! shiraz_bazrafsh Universalbox 12 04-14-2010 03:35
x620 imei repair ok but still imei 000000 rafik2533 Z3X-Team Products 1 11-27-2009 14:17
T11 fomat ok...full flash ok..but still no power.. rolly_van Infinity-Box 3 10-29-2008 11:08
PDS Repair and Fullflash OK but still dead U6 PEBL haxbox Smart-Clip 4 01-31-2007 12:57
Page generated in 0.22239 seconds with 10 queries
