03-06-2010, 17:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 758310 Status: Offline Sonork: 100.1601610 Thanks Meter: 71 | n73 hang at nokia then i flash that phone on mx key then it hang on nokia pls help me i need the solution pls mx team help |
03-06-2010, 17:41 | #3 (permalink) |
Banned Join Date: Oct 2009 Location: Inside Digital GSM Age: 35
Member: 1149774 Status: Offline Sonork: 0313-9541047 Thanks Meter: 1,163 | bro can u upload log here? then we can help u much better.............. visit here ur all prob solutions \SD Repair\Security Repair\SimLock Invalid\All Solution By MX-KEY http://forum.gsmhosting.com/vbb/show...35#post5383535 (¨`·.·´¨) `·.¸(¨`·.·´¨) Keep (¨`·.·´¨)¸.·´ Smiling! `·.¸.·´ Gsm_3GN |
03-06-2010, 17:45 | #4 (permalink) |
Member: 758310 Status: Offline Sonork: 100.1601610 Thanks Meter: 71 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 83104C9E023750AC3FADEFBFA580C806B87CE93D ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 22A00112EBB00254B6E0FBD23D114A8C8D8C0402 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 0098 01A1 - 0090 0095 [Toshiba ] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Original Imei: 35354802916988 Original Product code: 0564012 Bluetooth ID: 0021086237BD Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35354802916988-6 Product Code: 0564012 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353548029169886 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
03-06-2010, 18:25 | #9 (permalink) |
Member: 758310 Status: Offline Sonork: 100.1601610 Thanks Meter: 71 | hardware is ok because the phone working fine except sometime it create problem in calling i told customer that is not big issue but my customer want to flash it anyway and i check the pcb it is fine no waterdamage is there |
03-06-2010, 18:40 | #11 (permalink) |
Freak Poster Join Date: Dec 2009 Location: E G Y P T
Member: 1193296 Status: Offline Sonork: 100.1616292 Thanks Meter: 63 | whats the phone version now? try to flash using jaf interface. if you downgrade the version OR Flashed it with the same try to :::make Service >>> Quick Fix >>>BB5 SW DOWNGRADE FIX. |
03-07-2010, 08:32 | #15 (permalink) | |
Freak Poster Join Date: Sep 2004 Location: United Kingdom Age: 51
Member: 82796 Status: Offline Thanks Meter: 21 | Quote:
Phone goes to Local mode or not? If you need help we need some more information about phone, please checklogs, flash logs here. At first do check with UFS or JAF. Look , that APE is booting. Check by schematic APE voltage. Last edited by artusius; 03-07-2010 at 08:39. | |
The Following User Says Thank You to artusius For This Useful Post: |
N73 Hangs at startup | shok9992000@yah | Nokia Hardware & Hardware Repair | 10 | 04-11-2011 10:01 |
Nokia 1100 Hang at Nokia Logo | murtaza_nns | Nokia Hardware & Hardware Repair | 18 | 03-05-2011 05:42 |
n73 hang at nokia | b12345 | Nokia Base Band 5 ( BB-5 ) | 3 | 12-06-2010 09:40 |
nokia n70 hangs at nokia screen ? | imran_k | HWK | 4 | 07-13-2006 13:09 |
