05-30-2011, 15:33 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: IN-GSM-WORLD
Member: 1516406 Status: Offline Thanks Meter: 33 | Nokia C3-01 White Screen Blinking Problem. ## (ANSWERED) |
The Following User Says Thank You to MASTER GSM For This Useful Post: |
07-18-2011, 13:24 | #4 (permalink) |
Major Poster Join Date: Dec 2004
Member: 95807 Status: Offline Thanks Meter: 2 | Nokia C3-01 White Screen Blinking Problem. I Will Do Full Flash But Prolem Is Same. any help MXKEY Serial: [FT SCR2000 0] - C082130A Driver: NMWCD, ver: 7.1.32.65, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Processing MCU file: rm640__05.65.mcusw [BB5,XSR 1.6] size: 30.66 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 5CF93AD CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 2B60010DC4A803441C44B69E070402844B8FAF25 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 5CF93AD Verifying communication to device OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35830603081774_CE RT.rpl). CMT PAPUBKEYS HASH: 5AA09885C97BF3B0F6783A6337506F9394F346EF Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 45.06 MB CMT MuxOneNAND area [00020000-000203FF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 5AA09885C97BF3B0F6783A6337506F9394F346EF (RAP Certificate v1 261) sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT LDSP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 5.406 s Processing PPM file: rm640__05.65.ppm_i [BB5,XSR 1.6] size: 7.54 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 12 MB CMT MuxOneNAND area [020C0000-02CBFFFF] Flash programming ... Programming completed in 1.344 s Processing CNT file: rm640__05.65.image_i_0599374_005 [BB5,XSR 1.6] size: 36.15 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 66.06 MB CMT MuxOneNAND area [03340000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 6.375 s Total time for flashing process(boot+erase+write) was 29.110 s Waiting for device boot up ... Device found: nmwcdc\Nokia C3-01 USB Phonet, PORT_ID: BE5AB3B Verifying communication to device OK. Phone Type: RM-640 (Nokia C3-01) SW Version: V 05.65 26-11-10 RM-640 (c) Nokia Imei plain: 35830603081774-5 Product Code: 0599713 Battery voltage: 3957 mV, current: 148 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358306 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Formating FS: FILE2 ... Completed in 0.141 s Formating FS: FILE2 ... Completed in 0.110 s Formating FS: FILE2 ... Completed in 0.110 s Formating FS: FILE2 ... Completed in 0.125 s Formating FS: FILE2 ... Completed in 0.125 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.359 s |
08-11-2011, 17:02 | #5 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Hi, any one who have successfully solved this problem ? here too came a set in same condition. White Screen Blinking Problem flash writing is perfectly done rm640__06.05. (same product code) after writing Post Flash serial tunning of phone is not work set not turn to desired mode set power up and when we press accept button set goes to blinking consecutively. thanks advanced for sharing. regards, NEIL |
09-13-2011, 10:30 | #7 (permalink) |
Freak Poster Join Date: Apr 2007 Location: UAE
Member: 496124 Status: Offline Sonork: 100.1608380 Thanks Meter: 12 | mxkey team plz read this mV Phone type: RM-640 (Nokia C3-01 Touch and Type) Product code: 0599545 SW version: V 06.05 - 30-05-11 - RM-640 - (c) Nokia LanguagePkg version: 5 - 30-05-11 - RM-640 - (c) Nokia - V Version from phone: 06.05 Version from file: 06.05 Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1A8957F7 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 1BC0011242D50344F0B3C335283C969EC4126CE1 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 9.50.0 revision: 3.0 size: 0x3A40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW NewProtocol is not supported for current interface (). Please select correct loader version from 'Config' menu ! |
09-23-2011, 17:48 | #9 (permalink) | ||
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
I told you on post above you Quote:
09-23-2011, 19:30 | #12 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1660476 Status: Offline Thanks Meter: 0 | Here you can check about NOKIA C3 @ Mobile & Tablets: Nokia C2-03 |
