Old 12-08-2011, 19:24   #1 (permalink)
Member: 1080792
Sonork: 4d0ddc25d0db862fb2f2b62f1
Thanks Meter: 31
n73 logo display after flashing.
Dear respected team today i try to update n73 set old ver 4.0812.4.2.0 to 4.0839.42.2.1. then set is shows only nokia logo.
code:0543843. i try in 4.0580.43.0.1v23 again. same problem is repeat. help me about this problem. this 2 sets or good condition before flashing.
Old 12-08-2011, 20:26   #2 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
Thanks Meter: 143
post log from bus check or scan phone
Old 12-08-2011, 23:06   #3 (permalink)
rahul_rocks3's Avatar
Member: 1312746
Thanks Meter: 766
try flashing with ufs using flash file version 4.0580.43.0.1v23......ur handsets will be perfectly ok....tested many times
Old 12-09-2011, 06:32   #4 (permalink)
Member: 1080792
Thanks Meter: 31
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C083A3ED
Using device: HTI, FW ver: 00.24, SN: 00000DAA
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 57C6FBA773C428086E82BC6ED291971B9CB1FFD2
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 20500216B6767F56360FD6B925CD6E1338E650AD
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
Storage0: 00EC 01A1 - 0000 0015 [Samsung ] type: FLASH,NAND, asic:APE
Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Original Imei: 35571802905677
Original Product code: 0543843
Bluetooth ID: 0025479FC7CE
Phone type: RM-133 (Nokia N73)
SW version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
Imei plain: 35571802905677-5
Battery voltage: 4773 mV, current: 98 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355718029056775
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 12-09-2011, 11:58   #5 (permalink)
Member: 1423200
Thanks Meter: 53
have you tried a higher version of flahs file
Old 12-09-2011, 12:02   #6 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
Follow this will be ok 100%
backup rpl and full erase phone, afther that flash with latest version and write back rpl, rebuild simlock if needed.
Thats it
The Following User Says Thank You to adnann5 For This Useful Post:
Old 12-09-2011, 14:07   #7 (permalink)
Member: 1080792
Thanks Meter: 31
Thats it
i dont know full erase option. pl tell me step by step. thank u for respond
Old 12-12-2011, 10:30   #8 (permalink)
Member: 1080792
Thanks Meter: 31
My problem solved in jaf. I just flash it, my problem solved. Mx team what is the problem in mxkey. I used jaf 6months back. But today i used this jaf for this complaint. I think its a small dot of white paper like mxkey.
Old 12-12-2011, 10:36   #9 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
Dear, mxkey have many magic button.
next time you can try it.
Quick fix tab- BB5 downgrade fix.
Old 12-13-2011, 09:13   #10 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
yes,
he just need to use more HTI everyday, and forget that old dead tool.
move up!
Old 02-11-2012, 22:49   #11 (permalink)
Member: 11273
Thanks Meter: 14
Hi,
I have the same problem, I did what you wrote but now I have problem with IMEI: 12345678.....
is there any solution??
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: *********
Using device: HTI, FW ver: 00.50, SN: *********
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
APE Data :
ASIC MODE ID: 00
PUBLIC ID: B9DB60C928BC50232412E8B4D97C2E7C0951AAAF
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 27B00009D53E6350997FC4FCE7D7DE33F1BAAD13
ASIC MODE ID: 00
Reading CMT NPC (0x168 bytes).
Imei: 35643801924002
NPC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\***********002_NP C.rpl"
Erasing CMT NPC ... OK
Prog.status for Asic CMT ...
Applying BB5 SW Downgrade patch ...
Reading signatures ...OK.
PM backup saved to "C:\mobileEx\3.5\data\backup\***********002_201202 11193608_308.1.PM"
BB5 SW Downgrade patch OK.
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Updating CMT NPC ...OK
SW version: V 05wk47v38.2 27-03-07 RM-133 (c) Nokia.
Imei plain: 12345610654321-?
Product code: 0552011
Battery voltage: 4836 mV, current: 107 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei plain is invalid !!!
Imei net: 12345610654321?
Counter: 0/3, 0/10
Old 02-12-2012, 00:00   #12 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
u have RPL backup
NPC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\3564380192400 2_NP C.rpl"
write back your RPL / Recover IMEI
Old 02-12-2012, 11:35   #13 (permalink)
Member: 11273
Thanks Meter: 14
Originally Posted by maremestera View Post
u have RPL backup
thank you for reply I did exactly what you wrote but still stuck on logo any other idea?
RPL: "C:\mobileEx\3.5\data\backup\BB5_35643801924002_BA CK.rpl"
Restoring RF/BB DATA from backup ...
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0852F0B
Using device: HTI, FW ver: 00.50, SN: 000024C0
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Storage0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: FLASH,NAND, asic:APE
Updating CMT VARIANT ...OK
Prog.status for Asic APE ...
NOR: OK
NAND: OK
Updating PRODUCTCODE (0552011)... OK
Updating PSN (SBJ145901)... OK
Updating HWID (6020)... OK
Updating LOCK ...OK
Updating SUPERDONGLE_KEY ...OK
Updating CMLA_KEY ...OK
Imei plain: 35643801924002-9
Battery voltage: 4856 mV, current: 110 mA
Old 02-12-2012, 13:21   #14 (permalink)
Member: 691388
Thanks Meter: 371
now go to Service/ PM tab and press SD repair, then write good PM (yours from previous backup, or one from C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\RM-133.pm
Post full log after.
I'm not preaty sure about that, because "Updating SUPERDONGLE_KEY ...OK", so you can try also after SD repair, direct unlock (service> imei &.. > simlock TAB> update simlock
BR,
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Operator-Logo for 5110 MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-25-1999 15:50
Page generated in 0.27967 seconds with 9 queries
