Old 02-23-2010, 15:47   #1 (permalink)
AllGsmStore's Avatar
Member: 99509
Sonork: Whatsapp +971508482353
Thanks Meter: 210
n73 need solution
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Old 03-01-2010, 00:05   #2 (permalink)
Member: 382590
Thanks Meter: 41
I have a same problem with three phones
Old 03-01-2010, 00:50   #3 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
SUPER SD Auth
+ Write PM1,309
if not help
try check "BB5 Secure Validation"
 Added, BB5 Certificate Validation
    Usefull to identify SECURITY_TEST problem specially if SUPERDONGLE is valid
    Button located to [Phone Test->Various]
N73 doesn't have CCC and HWC.
moslty case from VARIANT data.
how to repair :
download N73 Variant data RPL from here
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
and write as RPL
br,
The Following 2 Users Say Thank You to Andra For This Useful Post:
i need Solution n73 not charging GSMJordan Nokia Base Band 5 ( BB-5 ) 3 09-25-2009 14:46
n73 display problem, i need solution boopathyp Nokia Hardware & Hardware Repair 0 03-29-2008 15:07
n73 "CAMERA HARDWARE FAILED" need solution kungpaoski Nokia Hardware & Hardware Repair 5 12-30-2007 01:37
Need solution for N73 headset icon Linkz Nokia Base Band 5 ( BB-5 ) 2 09-26-2007 04:49
Need N73 Unlock solution or service! yungcable Wanted Products 1 07-15-2007 12:53
Page generated in 0.14762 seconds with 9 queries
