07-06-2010, 13:33 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Back to GSM from AV
Member: 325999 Status: Offline Thanks Meter: 113 | N73 no RPL BACKUP WHEN ERASE (ANSWERED) REGARDS |
07-06-2010, 17:19 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
BR curvenger | |
07-06-2010, 22:32 | #3 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | and please do backup manually before doing any operation. Quote:
can you add more log info from this phone , and any backup do you have ? br, | |
07-07-2010, 06:27 | #4 (permalink) |
Member: 325999 Status: Offline Thanks Meter: 113 | This is the log Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0577467 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED This phone come to me for contact retailer (sl corrupted) so try with simlock rpl repair (with tick make sl rpl) but problem not solved then i tried some other way and in last i go for erase (with tick imei back up) & lost IMEI.My problem is i dont make manual back up but software must warn if back up not done. REGARDS |
07-07-2010, 07:00 | #5 (permalink) |
Member: 325999 Status: Offline Thanks Meter: 113 | As i post i tried every thing that i do for this problem & in most case ,but this time that not work even with other software too, so i go for erase .(with tick back up) Andra i have this back up REGARDS |
03-31-2011, 10:37 | #12 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | dear, dont take tension as i have solution. 1st go to imei & security click restore imei, small window will appear so click your drive where you have install mxkey, double click mxkey folder, then data folder, you will see the file i have attached, if not then double click backup folder in data folder & if not then copy this attachment file in backup folder & double click 3rd file which is rpl, mxkey will write your original imei, after this procedure your problem will be 10000000000000% solve, then what happen after this procedure please post it if any problem appear i will try to help you as i have solve this problem, click thanks if you solve by this procedure. have a good day...... |
Dejans Flasher Problem with 6150, NO Network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-03-2001 22:39 |
Wanted 6130 4.02 full backup Pls Read | Charly | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-06-2001 05:12 |
My 6150 (5.23) No network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-31-2001 15:56 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
