Old 06-12-2010, 12:57   #1 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
n73 saucessfully repair no problem with blade x server
SUCESSFULLY REPAIR N73 CONTACT RETAILER
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: B2CEF5A69AE611E22E581AF3132E73C5EBD96FB1
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1E700113ABC57C56DB5F3EA9E61EF0C4958A3E7D
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Original Imei: 35571802860374
Original Product code: 0577467
Bluetooth ID: 00247C4B2703
Phone Type: RM-133 (Nokia N73)
SW Version: V 05wk47v48.2 02-07-07 RM-133 (c) Nokia.
Imei plain: 35571802860374-2
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355718028603742
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
INIT SIMLOCKImei net: 355718028603742
Counter: 0/3, 0/10
Backup saved to "BB5_35571802860374_SIMLOCK.back"
Product: V 05wk47v48.2 02-07-07 RM-133 (c) Nokia.
ApeCoreSw: V 4.0727.2.3.1 05-07-2007 RM-133
Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x3948 bytes) ...OK
Sending CustomLoader(0x50B0 bytes) ...OK
Sending SecurityBlock(0x2000 bytes) ...OK
Sending SimlockBinary(0x3B0 bytes) ...OK
Calculating LOCK data ...OK
Receiving Unlocked PM, please WAIT ... OK
Unlocked PM saved to "C:\mobileEx\3.4\data\backup\355718028603742_UNLOC KED_308.1.PM"
Writing Unlocked PM ... OK
Completed in 24.405 s
Restarting phone ...
Reading Simlock info ...
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
REPAIR SD
Using cached productData[1E700113ABC57C56DB5F3EA9E61EF0C4958A3E7D] ...
Calculating SUPERDONGLE using security server ...
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0
Completed in 3.686 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-133_355718028603742_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
SUPER SD AUTH AND PM
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 6 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 44, size 182 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 0.580 s
PHONE SUCESSFULLY REPAIRPhone Type: RM-133 (Nokia N73)
ApeVariant: V 4.0727.2.3.1-10 05-07-2007 RM-133
Language Pack:
English,02 Uk
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 06-12-2010, 13:01   #2 (permalink)
i was darling's Avatar
Member: 1114281
Sonork: 100.1651778
Thanks Meter: 74
Iam getting problem while repair n73 please help me
Old 06-12-2010, 13:03   #3 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
[QUOTE=i was darling;5954494]Iam getting problem while repair n73 please help me[/QUOTE
EVERYBODY FACING THIS PROBLEM
WHILE SUPER SD AUTH
THIS ALL ARE FIREWALL PROBLEM
UNINSTALL MXKEY
AND INSTALL IT AGAIN IT WILL OK
THERE IS NO PROBLEM WITH SERVER
Old 06-12-2010, 13:27   #4 (permalink)
SHIBLU's Avatar
Member: 537829
Thanks Meter: 96
what net connection u used?
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:48
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.20407 seconds with 9 queries
