02-04-2010, 09:55 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | N73 sd repair error??????? SYSTEM ASIC ID: 000000010000022600010006010C192101013000 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 5.750 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-132_35897********_SD.RPL" missing NPC data. Certificate programmed successfully ! |
02-04-2010, 10:09 | #2 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | SD REPAIR DONE BUT SECURITY_TEST failed SORRY THIS IS THE CABLE ERROR BUT. Phone Type: RM-132 (Nokia N73) SW Version: V 05wk47v51.4 29-08-07 RM-132 (c) Nokia. Imei plain: 3589740******** Product Code: 0539354 ApeCoreSw: V 4.0738.3.1.1 05-12-2007 RM-132 ApeVariant: V 4.0738.3.1.1-23 05-12-2007 RM-132 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358974********* Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF PHONE START UP FAILED CONTACT THE RETAILER Last edited by omkarvitekar; 02-04-2010 at 10:15. |
02-04-2010, 10:13 | #4 (permalink) |
Freak Poster Join Date: Jun 2008 Location: ARROUND THE WORLD...."
Member: 796141 Status: Offline Thanks Meter: 25 | Try this method http://forum.gsmhosting.com/vbb/showthread.php?t=917883 if problem same try this http://forum.gsmhosting.com/vbb/showthread.php?t=918108 |
n70 sd repair error | sandrea | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-08-2010 12:13 |
Help n73 sd repair error ????? | sajjadahmad | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-27-2010 17:20 |
Ask N73 Sukses Repair SD | rie2n | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-05-2010 11:00 |
N73 sd data repair error | <<<MEGATRON>>> | Universalbox | 7 | 12-13-2009 13:31 |
