04-17-2011, 07:57 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | n73 SECURITY_TEST failed! SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35863401222991-4 Product Code: 0529785 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! itry every thing but some. mxkey team edit this rpl for tnx in avd Last edited by GSMTURBO; 04-17-2011 at 08:05. |
The Following User Says Thank You to GSMTURBO For This Useful Post: |
04-17-2011, 08:01 | #2 (permalink) | |
Freak Poster Join Date: Feb 2011
Member: 1522124 Status: Offline Sonork: 100.1597028 Thanks Meter: 40 | Quote:
04-17-2011, 08:08 | #3 (permalink) | |
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | Quote:
Update splock or write only npc data & do this job for security test failed - do not load any pm - mark : load rff bb from server - do PMM Auth - click write after auth is successful. | |
The Following User Says Thank You to Tarikul Islam For This Useful Post: |
04-17-2011, 10:20 | #11 (permalink) |
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | done with infinty with in 5sec here logs Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! ----------------------- PA_SimLock Version : PA_SL phone detected Done! Checking Camera Configuration... Operating mode is OK, no need change... Primary Camera #1 configuration info not exist Secondary Camera #2 configuration info not exist Repair SD procedure started... Phone Imei: 358634012229914 Key file exists, no need to read... Operating mode is OK, no need change... Writing Super Dongle Key... Ok Done! Local SX4 procedure started... Phone Imei: 358634012229914 Key file exists, no need to read... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Uploading RF/Battery tune to phone... Using : RM-133.pm Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 28 write - Ok Record 29 write - Ok Record 31 write - Ok Record 33 write - Ok Record 34 write - Ok Record 44 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Record 22 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! |
3330 v 412 fail with dfs 211 | denn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-19-2001 22:06 |
In wintesla 3310, what does cobba parrarel failed means | brittnee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-18-2001 16:05 |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
