03-02-2010, 01:43 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 444805 Status: Offline Thanks Meter: 45 | n73 test failed (all solution is applied but no luck) SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! "RM-133" folder created. Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 this phone is working even imie is invalid but shutoff (45mins to 1hour) when i try to experement in mxkey now is phone startup failed and contact retailer can anyone give and share a great solution in this problem |
03-02-2010, 04:11 | #4 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
special for your understanding, - all BB5 phone with damaged imei "12345.." need original RPL to get it works. | |
The Following User Says Thank You to gbluez For This Useful Post: |
03-02-2010, 13:39 | #6 (permalink) |
Freak Poster Join Date: May 2009
Member: 1035945 Status: Offline Thanks Meter: 54 | no solution yet,if you do not have the backups.........................first u have to repair imei,then u can be able to repair it...............and u have to wait for that solution |
N73 test failed security problem?? [ Solved ] | geovanny78 | Cyclonebox | 11 | 02-13-2010 06:44 |
e63 only success with MXkey (with UB and Mtbox but no luck) | blueteamgsm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 02-01-2010 06:59 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
All Locks is opened but phone is locked on Z530i | JAVA Good | Cruiser Suite | 8 | 11-26-2006 18:38 |
