Old 09-28-2011, 22:42   #1 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
Question n73 unlock problem ## (ANSWERED)
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Phone type: RM-133 (Nokia N73)
SW version: V 05wk47v48.3 02-07-07 RM-133 (c) Nokia.
ApeCoreSw:
V 4.0727.2.2.1
Using cached productData.
PUBLIC ID: 0540010E5BE90154D3EB9ACB2FBABF053C161C85
PRIVATE ID: 69347CDB8C89F42CCA78475ADC70197120AF4752
E-FUSE: 025B2301
SEC ROM CRC: 40830040
Updating SIMLOCK...
error 0x1
Reading Simlock info ...
Imei net: 356406019643385
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
i make repair sd ,super sd auth, pm them unlock but i have this error
need help maybe a bug in software
Old 09-28-2011, 22:55   #2 (permalink)
TICTAC_M's Avatar
Member: 331361
Thanks Meter: 155
ApeCoreSw:
V 4.0727.2.2.1
E-FUSE: 025B2301
Updating SIMLOCK...
error 0x1
Counter: 0/3, 0/10
but your phone is unlock! what is your problem?
Old 09-28-2011, 23:01   #3 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
contac retail contac your resseler
Old 09-28-2011, 23:22   #4 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
phone start-up failed. contact the retailer n73
SW version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
Imei plain: 35640601964338-5
Product code: 0539354
Battery voltage: 4449 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
Old 09-28-2011, 23:37   #5 (permalink)
rkinfo_khan's Avatar
Member: 978268
Thanks Meter: 83
phone start-up failed. Contact the retailer n73
phone type: Rm-133 (nokia n73)
sw version: V 05wk47v61.1 09-07-08 rm-133 (c) nokia.
product code: 0539354
battery voltage: 4449 mv, current: 0 ma
language pack:
- not available.
Simlock invalid!
Superdongle_key[mx] seems to be valid
simlock_test failed!
Security_test passed
imei net: 356406019643385
version: Simlock server version 63
counter: 0/3, 0/10
config_data: Ffffffffffffffff
profile_bits: Ffffffffffffffff
block1: 1=closed(mccmnc), data=00101f
your sim lock is invalid try to repair sim lock in service tab:d
Old 09-28-2011, 23:41   #6 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
Question
again look first log there you fin the problem
SW version:
ApeCoreSw:
V 4.0727.2.2.1
PUBLIC ID:
PRIVATE ID:
E-FUSE:
025B2301
SEC ROM CRC:
40830040
Updating SIMLOCK...
error 0x1
Imei net:
356406019643385
Version:
Counter: 0/3, 0/10
CONFIG_DATA:
2440700000000000
PROFILE_BITS:
0000000000000000
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
Old 09-29-2011, 00:05   #7 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
done like this
1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl)
2. erase old pm ( go > pm tab > erase )
3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this)
4. Erase pm again (go > pm tab > erase )
5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei)
6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309)
7. erase pm again
8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert)
9. give full factory reset
Old 09-29-2011, 00:08   #8 (permalink)
TICTAC_M's Avatar
Member: 331361
Thanks Meter: 155
first your see sticker back phone rm-132 of rm-133.
second do make backup to rpl.
eraser phone.
flash with rm of sticker.
write rpl.
repair sim lock.
repair sd.
write good pm.
it is for resolver "contac retail contac your resseler" and
good lock
Old 09-29-2011, 04:51   #9 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
Old 09-29-2011, 04:59   #10 (permalink)
Member: 1629736
Sonork: aayushjaiswal
Thanks Meter: 272
1st u recovr cert. Then ppmautho. Or write perfect pm file without 308 then reset all ur problem is solve
Old 09-29-2011, 08:25   #11 (permalink)
Tarikul Islam's Avatar
Member: 1310148
Sonork: 100.1601928
Thanks Meter: 293
Erase EEPROM then try.
Post result
Old 09-29-2011, 12:02   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
messy eeprom :
- backup rpl just in case
- erase (not safe erase): get addr, select eeprom.
- repeat simlock repair.
Old 09-29-2011, 17:29   #13 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
done npc was damage i use this and phone work perfect
7. erase pm again
tanks but this was the problem . to many spam
Old 09-30-2011, 08:49   #14 (permalink)
Member: 965137
Thanks Meter: 30
I agree with wilmer.... same procedure done here!
The Following User Says Thank You to LuverBoy For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
Page generated in 0.21359 seconds with 9 queries
