Old 10-01-2012, 14:27   #1 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 551
N73 whats problem this?
i got nokia n73 phone start up faild...
i try repair but not success... I read all post in forum but this problem not solved
see logs here..
first bus check...
Phone type: RM-133 (Nokia N73)
SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia.
Imei plain: 35291602987330-5
Product code: 0529607
Battery voltage: 4842 mV, current: 41 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
Phone version(4.0850.43.0.1) outdated, selected version is: 4.850.43.0
Phone version(4.0850.43.0.1) outdated, latest version on server is: 4.0839.42.0.1
Imei net: 352916029873305
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
When updating splock.....
ApeCoreSw: V 4.0850.43.0.1
Using cached productData.
PUBLIC ID: 25A00004D2F86A50C6473E7AB4504FD804736537
PRIVATE ID: 0127173D94458512E6ADDD53B7A8ACAA7A6553C2
Updating SIMLOCK ...error 0x1
Reading Simlock info ...
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
After splock update.....
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
I thought its ok now....
BUT right after bus check again.. This
Selected firmware certificate matched.
Original Imei: 35291602987330
Original Product code: 0539295
Bluetooth ID: 001F01B6DAEC
SIMLOCK PA identifier:
[0] PA_SL
Battery voltage: 4842 mV, current: 35 mA
Language Pack:
- not available.
SIMLOCK invalid!
Counter: 0/3, 0/10
But this going back to this problem... anyone can help me whats the problem? and how to solve??
Thanks in advice...
Old 10-01-2012, 15:41   #2 (permalink)
Member: 983663
Sonork: 100.1623270
Thanks Meter: 551
Thanks for guide now problem solved.
Page generated in 0.14613 seconds with 9 queries
