Old 06-28-2010, 03:42   #1 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
N76 Phone Start up failed!!!
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101011103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1220011577580058446A4C781D366DB6CFB0A0A9
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: F2C6EBADC86E6189
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0030 - 0060 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 500F1CC61F6C1F570D3EF99F62B9AA86C53B2049
TransmissionMode: DDR&TX2
Original Imei: 35395401279394
Original Product code: 0543076
Bluetooth ID: 001BAFB20A68
Phone Type: RM-135 (Nokia N76)
SW Version: V 06wk41v21.4 05-04-07 RM-135 (c) Nokia
Imei plain: 35395401279394-0
Product Code: 0543076
ApeCoreSw: 10.0.035
ApeVariant: 10.0.035, ApeTest: rm135_ENO_x_2007wk07v0.040
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353954012793940
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Still phone startup failed!!!!
pls help.
thanks.
The Following User Says Thank You to 089999945 For This Useful Post:
Old 06-28-2010, 03:52   #2 (permalink)
Member: 588393
Thanks Meter: 8
try to flash to higher ver. then bus check to mx-key..
Old 06-28-2010, 06:28   #3 (permalink)
GsmEasy's Avatar
Member: 608359
Sonork: 100.1576815
Thanks Meter: 6,678
use sx4 server and write full PM your set will be fine
The Following User Says Thank You to GsmEasy For This Useful Post:
Old 06-28-2010, 06:46   #4 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
 SIMLOCK_TEST passed
no need to flash this phone
no need to load pm
just just format user area via mxkey(C,D,Z)
still smae problem faced just run self test then post there
some time hardware make this problem
Old 06-28-2010, 06:49   #5 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
try to flash to higher ver and use sx4 server and write full PM your set will be fine
Old 06-28-2010, 07:06   #6 (permalink)
pawans's Avatar
Member: 346345
Sonork: jhon18
Thanks Meter: 56
hi mates try to format the phone use mxkey
step1 : go QUICK FIX
step2: check BB% RAP3nand erase user area:
step3: DO JOB SELECTED
if same problem hardware fault..
Old 06-28-2010, 11:16   #7 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
 SIMLOCK_TEST passed
no need to load pm
Phone Type: RM-135
SW version: V 06wk41v46 06-11-07 RM-135 (c) Nokia
ID Test name Startup Result
46 UEM_CBUS_IF Y PASSED(00)
3 EAR_DATA_LOOP Y PASSED(00)
12 SIM_CLK_LOOP Y PASSED(00)
13 SIM_IO_CTRL_LOOP Y PASSED(00)
33 SIM_LOCK N PASSED(00)
93 SECURITY N PASSED(00)
90 PWR_KEY N !NOT EXECUTED(03)
2 CURRENT_CONS N !NOT EXECUTED(03)
20 BACKUP_BATT N !NOT EXECUTED(03)
56 SLEEPCLK_FREQ N !NOT EXECUTED(03)
49 VIBRA N !NOT EXECUTED(03)
96 HOOKINT N !NOT EXECUTED(03)
101 BTEMP N !NOT EXECUTED(03)
108 EXT_DEVICE N !NOT EXECUTED(03)
86 CDSP_RF_BB_IF N !NOT EXECUTED(03)
83 CDSP_RF_SUPPLY N !NOT EXECUTED(03)
85 CDSP_TX_IQ N !NOT EXECUTED(03)
74 CDSP_TXC_DATA N !NOT EXECUTED(03)
82 CDSP_PWR_DETECTOR_BIAS N !NOT EXECUTED(03)
79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03)
81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03)
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
7 KEYBOARD_STUCK N !NOT EXECUTED(03)
21 LPRF_IF N !NOT EXECUTED(03)
22 CAMERA_IF N !NOT EXECUTED(03)
37 SEC_CAMERA_IF N !NOT EXECUTED(03)
44 LPRF_AUDIO_LINES N !NOT EXECUTED(03)
59 MAIN_LCD_IF N !NOT EXECUTED(03)
36 SEC_LCD_IF N !NOT EXECUTED(03)
71 BT_WAKEUP N !NOT EXECUTED(03)
107 BT_SLEEP_CLK N !NOT EXECUTED(03)
pls help me.
thankls.
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Page generated in 0.19282 seconds with 9 queries
