Old 03-29-2011, 09:49   #1 (permalink)
Member: 60687
Thanks Meter: 32
...n8-00 flash error... (ANSWERED)
log is here:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011)
CMT Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1]
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 2B300113DA32004989AF22BF833173A82A87A04A
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 9.50.0 revision: 3.0 size: 0x3A40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
Please select correct loader version from 'Config' menu !
RX Buffer:
hoe to fix this error!!! wbr
Old 03-29-2011, 10:01   #2 (permalink)
shohag's Avatar
Member: 147116
Sonork: 100.1578260
Thanks Meter: 316
HWK UFS box not supported new Hash.....
use ATF as interface to flash fbus cable.....
or USB flash..........
Old 03-29-2011, 10:39   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
all saras box not support all new nokia protocols. you will need other supported FBUS interface.
you also can use only usb cable, choose 'Nokia USB ROM'.
don't use any usb hub, plug directly usb flashing cable to pc port.
Old 03-29-2011, 21:46   #4 (permalink)
Member: 60687
Thanks Meter: 32
...thank you for answer...
....i have mt-box, jaf, twister, micro hwk, universal ....can i use one of this boxes for n8-00 fbus flashing?
wbr
Old 03-29-2011, 23:18   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
all boxes with you are not supported. forget potato.
you can handle all rapuv11 phones by using ONLY usb cable, as i wrote above.
Old 03-29-2011, 23:45   #6 (permalink)
Member: 942817
Thanks Meter: 20
how about ATF lite, is it support?
Old 03-30-2011, 00:36   #7 (permalink)
Member: 790497
Sonork: 87654321
Thanks Meter: 79
bro why don,t u listen to him as he is repeating again and again.mxkey is the best for your problem to solve.
just simpally connect phone direct in pc with usb cable and in interface where u choose ufs etc simpally select NOKIA USB ROM and flash your phone it will flash your phone mayb less then 10 mints.no other box will flash your phone faster and better than mxkey
i have also face and solve the same problem.
use latest version or 1.8 version is good for flasing.
good luck.
br
The Following User Says Thank You to nsbabar For This Useful Post:
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.21325 seconds with 9 queries
