12-30-2011, 07:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1276771 Status: Offline Thanks Meter: 33 | n8 flashing error customer said it hang up alout so i flashed with usb with infinity box flashing going to be complete but at last stape it said after flash not accepted i tried many different firmware version but same here is bus check result of mxkey MXKEY [FT SCR2000 0], SN: C0843E6E Using device: HTI, FW ver: 00.24, SN: 0000DD76 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 1A7002042DD60344F90C5698CD6E244F9AA004F0 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.24.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.24.0 revision: 3.0 size: 0xC6B13 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Original Imei: 35698804445609 Original Product code: 0599464 Bluetooth ID: 782EEFC1DE47 SIMLOCK PA identifier: [0] PA_SIMLOC30 mxkey flashing error MXKEY [FT SCR2000 0], SN: C0843E6E Using device: HTI, FW ver: 00.24, SN: 0000DD76 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 1A7002042DD60344F90C5698CD6E244F9AA004F0 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.24.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.24.0 revision: 3.0 size: 0xC6B13 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Processing MCU file: RM-596_024.001_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 122.50 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning ...OK Erase size: 228.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 5 min 58.156 s Processing PPM file: RM-596_024.001_13.01_MEA_A_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 47.28 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 2 min 18.235 s Processing PPM file: RM-596_024.001_C08.01_MEA_5_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 14.80 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15 MB CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 0.437 s Processing CNT file: RM596_APE_ONLY_ENO_11w15_v0.148.fpsx [BB5,XSR 1.6] size: 4.05 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS*ENO block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 12.219 s Processing CNT file: RM-596_024.001_U08.01_79.92.uda.fpsx [BB5,XSR 1.6] size: 80.77 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 262 MB CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 3 min 53.563 s Total time for flashing process(boot+erase+write) was 12 min 37.922 s at last step it gives error phone not respond reset manualyy?? what is the solution???? i have tried diffrent firmware and box and i tried with usb also the same error??? |
12-30-2011, 08:55 | #2 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Do not want to tell you Age: 38
Member: 1538800 Status: Offline Sonork: Offline Thanks Meter: 18 | Use mobileEx 3.5 (rev1.6), and then update your HTI. If the problem is not resolved, please use the HTI FBUS |
The Following User Says Thank You to haixiang For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
