01-12-2011, 19:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: United State
Member: 229658 Status: Offline Thanks Meter: 60 | N8 phone lock????? (ANSWERED) is it through flashing? if yes help me with the file. |
01-12-2011, 20:13 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | brother just do bus check and then go to imei tab and over there click on read user code.....in this way u will get the security code with which the phone is locked just enter it to the phone and un-lock your user code |
01-13-2011, 20:40 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | If usb method by buscheck can make it goes to local mode, you will need fbus cable to reset it without flashing. how to usb rom: - select Nokia USB ROM as interface, select phone, select flashes by market drop down. click BUSCHECK, follow all program suggestion. After buscheck done, you should see "Service Tab" is activated now. And if not, you will need fbus cable to reset it w/o flashing. |
The Following User Says Thank You to gbluez For This Useful Post: |
01-13-2011, 21:10 | #6 (permalink) | ||
Freak Poster Join Date: May 2009 Location: Wales
Member: 1035679 Status: Offline Thanks Meter: 62 | Quote:
2 goto service tab 3 click on imei & security tab (please select category on the left) 4 click on user code 5 then the read button in this way u will get the security code with which the phone is locked just enter it to the phone and un-lock your user code and dont forget to thank rahul_rocks3 | ||
04-15-2011, 10:55 | #8 (permalink) |
Junior Member Join Date: Apr 2006
Member: 262691 Status: Offline Thanks Meter: 2 | just insert sim into phone.start phone normaly.lock will stil display but phone will be online and able to recieve calls.then insert usb cable and phone will be detected and change to testmode, do factory reset on unibox(think other software will work as well).no lock code is off |
04-18-2011, 21:17 | #9 (permalink) |
Freak Poster Join Date: Jan 2004 Location: czech rep.
Member: 49095 Status: Offline Thanks Meter: 10 | You are wrong, SECURITY CODE you can fix with USB connection, you have to put phone into LOCAL or TEST MODE and you have to FORMAT USER AREA in disk C: Neither flashing or factory settings doesn't work for me on C7 (likewise N8...), only FORMAT USER AREA successfully reset your security code. BR |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
