02-07-2010, 06:43 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 249351 Status: Offline Thanks Meter: 45 | N82 after repair blinking ... Code: Phone Type: RM-313 (Nokia N82) SW Version: V 06wk41v64.24 05-11-09 RM-313 (c) Nokia Imei plain: 35898401994492-8 Product Code: 0554982 ApeCoreSw: 35.0.002 ApeVariant: 35.0.002, ApeTest: rm313_eno_2008wk06updv0.030 ContentPack: V 015 09-12-08 u04 RM-313 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358984019944928 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 10 min 10.734 s Code: Original Product Code: 0561053 Reading RAP VARIANT (0x0 bytes) VARIANT empty ! Reading RAP CCC (0x160 bytes) Product Code: 0560975 Product Code missmatch ! Reading RAP HWC (0xD4 bytes) Product Code: 0560975 Product Code missmatch ! |
02-07-2010, 06:45 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | have u backup rpl and pm if have then write rpl backup and chek if not then use higher version and rewrite backup rpl or recover cert |
02-07-2010, 06:58 | #4 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: GSM WORLD
Member: 636786 Status: Offline Sonork: 100.1576399 Thanks Meter: 34 | flash Quote:
hi maybe after flash last FW will be ok | |
02-07-2010, 07:53 | #6 (permalink) |
Freak Poster Join Date: May 2008 Location: VietNam Age: 36
Member: 768903 Status: Offline Thanks Meter: 43 | Select flash file for Ini .Phone blinking can downgrade and solve problem by HWK , without use lastest firmware . If before flashing phone usually , after Fl phone blinking ... please downgrade to RM-313_30.0.019 If can't solve, use Eno flash to phone . Tested solved N82 binking after flash lastest firmware . |
02-08-2010, 11:43 | #14 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | use PM auth . and write PM without [308] use auth SX-4 can sych that. br, |
The Following User Says Thank You to Andra For This Useful Post: |
K810 blinking lcd after repair by dreambox | meisam | DreamBox | 21 | 06-06-2008 08:18 |
K618 white lcd blinking after repair gdfs | tgcommss | DreamBox | 2 | 05-10-2008 18:11 |
need help n82 after format phone dead | bilousoft | Chinese Cocktail | 1 | 12-27-2007 10:44 |
C261 Blink After Repair Eprom | fouad189 | Smart-Clip | 7 | 05-17-2007 10:23 |
how to repair blinking 535 afterred box unlock | shahzad.akram | Philips | 4 | 07-19-2004 09:26 |
